Setting Ibus up on a fury F3
How can I setup my receiver it is a flysky one so Ibus to a fury F3.  I got a link to the manual below.  It just states sbsus, do I use the same pin and use ibus instead or is there an other way?
https://quadquestions.com/uploads/furyf3manual.pdf
I'm sure someone can give you a definitive answer, but I do know that the difference is that sBus has an inverted signal and iBus doesn't. So if you connect the signal wire to the sBus pad on the Fury 3, well, it's not going to work. So I think you're going to have to connect to a different UART that's non-inverted, or determine if you can turn the inverter off
That’s what I was trying to look for in the manual to see if I can turn it off or use another pin for ibus but there is nothing in there. There’s a pin for ppm but correct me if I’m wrong that is analog and allot slower.
You should be able to connect to SBUS and in CLI "sbus_inversion = off" and "save"
Otherwise could I use the uart3 rx pin?
If it was me, I'd just try and see if it worked. You can't hurt anything
UART3 RX will work.
  Setting up a Profile for Indoor Fllying FPVme 7 267 05-Dec-2023, 08:59 PM
Last Post: FPVme
Question Setting AUX channels initial level TVT 6 565 31-Oct-2023, 03:37 PM
Last Post: wizofwires
  Help setting up a cinewhoop PJKMBAKER 40 1,436 21-Oct-2023, 09:09 AM
Last Post: PJKMBAKER
  Omnibus F4 can't get IBUS RX working after flashing tekknyne 4 570 27-Jul-2023, 02:11 PM
Last Post: aster1sc
  Setting up for the first time GabeFPV 22 1,603 19-Dec-2021, 11:42 PM
