Threads: 30
Likes Given: 714
45 I'm sure someone can give you a definitive answer, but I do know that the difference is that sBus has an inverted signal and iBus doesn't. So if you connect the signal wire to the sBus pad on the Fury 3, well, it's not going to work. So I think you're going to have to connect to a different UART that's non-inverted, or determine if you can turn the inverter off
Threads: 23
Likes Received: 8 in 8 posts
Likes Given: 3
0 That’s what I was trying to look for in the manual to see if I can turn it off or use another pin for ibus but there is nothing in there. There’s a pin for ppm but correct me if I’m wrong that is analog and allot slower.
Threads: 125
Likes Received: 3,738 in 2,835 posts
Likes Given: 99
388 You should be able to connect to SBUS and in CLI "sbus_inversion = off" and "save"
Threads: 23
Likes Given: 3
0 13-Feb-2018, 05:43 PM (This post was last modified: 13-Feb-2018, 05:43 PM by elliep.) Otherwise could I use the uart3 rx pin?
Threads: 30
Likes Given: 714
45 If it was me, I'd just try and see if it worked. You can't hurt anything
