Motor thread
Hi
I noticed some of my screws being quite lose and apparently the threading inside my motors is getting destroyed from crashing. Didn't think that would be the first thing prevent me from staying in the air. Any suggestions to either make it less likely to get destroyed or maybe a way to still connect my motors securely after some of the threading is partly gone?
Lazie
If you are not already using blue thread lock when you screw your motors to your arms, you should be!
That way, they won't get loose with the vibrations. For those motors where you have already damaged the threads, the thread lock will help, but there's only so much you can do and very few motors have enough excess material to enable cutting new, slightly larger threads and matching those with oversized screws.
(24-May-2017, 06:23 PM)unseen Wrote: If you are not already using blue thread lock when you screw your motors to your arms, you should be!
Yeah, I won't try to cut new one's. I'll try to find some thread lock.
(24-May-2017, 06:53 PM)laziegoblin Wrote: Yeah, I won't try to cut new one's. I'll try to find some thread lock.
BLUE thread lock only!
If you use the red stuff, you'll never get the screws out again. If there are other screws that hold your frame together that don't use nylock nuts or some other method to prevent the screws vibrating loose, you should also use blue thread lock on those as well.
Did you use 4 screws per motor, or only 2?
In the beginning i thought 2 were enough lol... until a motor fell off. Luckily it was right at start, not mid-flight. Definitely my shortest flight ever. Big Grin
  • unseen
(24-May-2017, 09:03 PM)fftunes Wrote: Did you use 4 screws per motor, or only 2?
Nono, I did screw 4 in Big Grin  I did order some blue locktite stuff.
[-] The following 1 user Likes laziegoblin's post:
  • fftunes
When I had my motor fiasco (testing after the rebuild) I happened to get into the air with only a single screw on one of the motors! I noticed the ticking/vibrating sound and landed within a few seconds but it actually took off even with the motor barely mounted lol...
blue always from now on... even during testing :p
Always listen to Unseen... he knows best Wink
carl.vegas
  • fftunes, unseen
  Motor/esc problem Axel 42 1,034 26-May-2024, 10:15 AM
Last Post: wizofwires
  Motor under water Eyes.fpv 5 183 04-May-2024, 05:16 PM
  What motor to choose on 3.5" cinewhoop? Fpv_Snidde 4 394 02-May-2024, 11:21 AM
Last Post: Fpv_Snidde
  protect motor wires Eyes.fpv 12 340 01-May-2024, 09:03 AM
Last Post: Eyes.fpv
Wink 0% throttle motor dsync when flipping? mojohoojo 3 116 26-Apr-2024, 05:13 PM
Last Post: mojohoojo
