Motor RUN-AWAY
OK im hooked up to Betaflight checking config.... getting ready to do a maiden flight.  when powered up the motors idle at 1025 where set...but when throttle is increased and brought back down .. the motors continue to rev higher and higher... im guessing to about 1200 / 1300....and will not come back down to idle... i rebinded the receiver .... and went on BLHeli and calibrated the ECS's  and still the same... in all my flight modes..  "ANGLE, HORIZON, and ACRO" ..  and i noticed that when i pick up the quad and move it around "front to back / tilt side to side i can feel the motors compensating like in a safe mode...   NOW .. i went back in and upgraded the FC the the Newest Colibi race firmware 3.3.1 and did not put the ANGLE and HORIZON modes in .  and all seems to be OK now.......
Are you talking about doing this on your bench with no props on? This is quite normal
  • Drone0fPrey
(20-Apr-2018, 06:18 PM)RENOV8R Wrote: Are you talking about doing this on your bench with no props on?  This is quite normal
YES.. on the bench.. no props.... is this normal when "ANGLE""and "HORIZON" modes are set up .. because it doesn't do it after i deleted the Modes ????
That happened to me once. Turned out that Air Mode was on. I went round and round trying to figure it out and made a video showing the problem. I was about to post it when I decided to check one last thing and sure enough it caused that exact issue. Might not be yours but it's worth checking.
I'd rather be flying!
My Builds
YouTube
What's happenning is the FC is not seeing a change in the gyro trace when trying to compensate the quads angle/attitude. Without props on the bench the FC keeps trying to change motor speeds to get the quad oriented how it thinks it should be. In acro all motors will spool up similarly as the FC is not trying to level the craft, where with angle and horizon modes the FC is trying to level itself as soon as you arm.
Hope this clarifies things a bit.
Very normal Wink
The Obsession IS Real!
(21-Apr-2018, 01:12 PM)Drone0fPrey Wrote: What's happenning is the FC is not seeing a change in the gyro trace when trying to compensate the quads angle/attitude. Without props on the bench the FC keeps trying to change motor speeds to get the quad oriented how it thinks it should be. In acro all motors will spool up similarly as the FC is not trying to level the craft, where with angle and horizon modes the FC is trying to level itself as soon as you arm.
Very normal Wink
YES it did thank you sooo much my friend......
(20-Apr-2018, 07:30 PM)Hypurr Wrote: That happened to me once.  Turned out that Air Mode was on.  I went round and round trying to figure it out and made a video showing the problem.  I was about to post it when I decided to check one last thing and sure enough it caused that exact issue.  Might not be yours but it's worth checking.
Hypurr you were absolutely correct.  the "AIRMODE" tab was on..... how i dont know cuz i never use that ... but oh well !!!!   thank you my friend.....  JD
[-] The following 2 users Like JD Quad Jammer's post:
  • Tom BD Bad, Hypurr
Glad you got it worked out. Smile
My Builds
YouTube
this is what fixed my issues!!!! thank you ohhhh so very much
  Motor/esc problem Axel 42 994 26-May-2024, 10:15 AM
Last Post: wizofwires
  Motor under water Eyes.fpv 5 180 04-May-2024, 05:16 PM
  What motor to choose on 3.5" cinewhoop? Fpv_Snidde 4 354 02-May-2024, 11:21 AM
Last Post: Fpv_Snidde
  protect motor wires Eyes.fpv 12 313 01-May-2024, 09:03 AM
Last Post: Eyes.fpv
Wink 0% throttle motor dsync when flipping? mojohoojo 3 113 26-Apr-2024, 05:13 PM
Last Post: mojohoojo
