30-Jul-2020, 08:36 PM
Hi -
I am working on a new build that uses the Kakute F7 AIO and Tekko32 esc's. I was having some soldering issues and got some good advice from this forum and while not great, my skills are slowly improving.
My current issue is that while I can connect to the FC using Betaflight, I can't access the esc using BLHeliSuite32. All was working a few days ago, but something happened when I reworked the solder connections. Images of the setup are below.
I am wondering if I have shorted something on the FC - the image below shows that I have very little resistance between the positive battery pad and the 0m25 component.
The board doesn't short when I connect it to the battery pack but the esc begins to get warm. I assume that this shouldn't be the case but I am not sure if this is an FC problem or ans esc problem.
Any tips on how to troubleshoot problems like this!
Thanks!
Thanks!
