Poll: Which Charger is the best to get to charge most/fastest and has long term use?
You do not have permission to vote in this poll.
Get the iCharger 306B !
33.33%
2 33.33%
Get the Cellpro PowerLab 6!
50.00%
3 50.00%
Other! I'll tell you what and why in a reply.
16.67%
1 16.67%
Total 6 vote(s) 100%
* You voted for this item. [Show Results]
Chargers, Power Supplies and headaches/wallet aches
OK so my Radiolink CB86-Plus is slowing me down a LOT now that I am actually wanting to fly more. I am researching around for good chargers and found two that are probably what I am going to decide between.
The first is the iCharger 306B. the second, and one I am leaning most to is the FMA PowerLab 6. Both have great features but I think the Powerlab 6 is the best option.
Now looking around for the ever important Power Supply I am shocked by the prices out there. I believe I am going to go with two of the 2Z0 RC 575W Modular RC Power Supply 12v/47A in series configuration so I get 24V/47A as the Powerlab is limited to 50A input. The price at $59,99 each is better than anything else I have found. It is too bad that I can't get access to some server power supplies here in my Data Center, ut that is a no-no. So I have to purchase some somewhere and I like what these are capable of out of the box.
I am going to try a Poll and see if it works. Please tell me which Charger you would go with in the poll. If it is "other" please let me know why? If you know af any good 24V/50A power supplies or better at a great price I would appreciate that input also.
Ok let's try the "Poll" option
I am a developing Racer - getting better.....
BNF Quads: <250 Eachine>; <250 Walkera Advanced CC3D>; <250 Vortex Pro>
Built: Dronz Fury 252 RX ; Speed Addict 210-R
Building: <Deciding on Third build - Suggestions?>
I voted for the "Other", and here is why.
Given budget is a prime reason for any purchase and I am mindful of that, I will however advise at least looking at the following charger.
http://www.horizonhobby.com/product/mult...r-hrc44167
[Image: Screen_Shot_2016_03_18_at_6_01_11_pm.jpg]
I have had one of these for the last 4 years and charges everything from my 6S 5000mAh to 1000mAh 3s, can be used at home off AC, or out in the field off DC, your car battery.
It can charge 4 lipo's at once and can be 4S, 6S, mix and match as you please.
While a bit pricey it really is a nice one stop shop, no need for a PSU as it has one built in, but does offer you the option to use a DC supply should you wish.
From a personal viewpoint and having used one I can highly recommend it.
(18-Mar-2016, 08:37 AM)BigglesFPV Wrote: I voted for the "Other", and here is why.
How long to charge four 4S batteries?
I only charge at 1C, 2C in the field at times, so roughly for 4 x 1300mAh 4S 65C about 70 minutes.
Thanks BigglesFPV! I appreciate the information. I'll keep it under consideration. I don't see ever going over 1C myself, but I have to consider how many "parallel" I'll be charging. I want to be able to do 6 or more at 1C as right now I can do up to 8 on my Radiolink CB86-Plus, but it is fickle at best. Works but takes hours and hours. I want to spend less time charging. That is why I narrowed down to two above as they both will do high wattage, but need power to get them there. Thereby necessity of buying a powerful power supply additionally.
70 minutes is better than what I have now using only balance plug charging.
I also like being able to drill down if I want into the health of my batteries. Both of the ones above do that, and look like they will last years for me, as does your 200 Watt unit. I am looking forward to what others will input.
You are either a night worker like myself or in a part of the world that is daylight when I am in the dark eh BigglesFPV?
In Australia..Currently 6:46pm 18th March, 2016. :-)
(18-Mar-2016, 08:55 AM)BigglesFPV Wrote: I only charge at 1C, 2C in the field at times, so roughly for 4 x 1300mAh 4S 65C about 70 minutes.
Steve how do you charge at the field? with large pack or generator?
(18-Mar-2016, 11:07 AM)Oscar Wrote: Steve how do you charge at the field? with large pack or generator?
I have a dual battery system in my 4wd, so can easily charge all day no problems. Can run my 4 port DC charger.  :-)
(18-Mar-2016, 11:35 AM)BigglesFPV Wrote: I have a dual battery system in my 4wd, so can easily charge all day no problems. Can run my 4 port DC charger.  :-)
okay the next thing i am going to buy is a 4wd Big Grin
(18-Mar-2016, 11:55 AM)Oscar Wrote: okay the next thing i am going to buy is a 4wd Big Grin
Way to GO!!!!!!!!!!!.
My old diesel had a huge battery.
Found an RCGroups review that speaks highly of your charger BigglesFPV .....
(18-Mar-2016, 01:51 PM)Hebrews12v2 Wrote: Found an RCGroups review that speaks highly of your charger BigglesFPV .....
Like I said, It is a really great charger and has and still is serving me well. Big Grin
Ok People. Several have visited the thread... give me a hand and vote in the poll...don't leave me hanging here! Oscar... whatcha know buddy?
68 views at time of this posting and no one is helping me out besides BigglesFPV? Come On guys and gals... at minimum click on the poll to tell me which you prefer. I "tried" to make it an easy question and I appreciate you taking time to answer.......
  Quad won't Arm Low Power Mode Unable to record videos Seanalami 3 558 27-Mar-2022, 11:13 PM
  Damn Power Lines! sirdude 8 1,175 29-Oct-2018, 05:23 PM
Last Post: sirdude
  Help Power cable partially cut in4rit 9 2,113 10-May-2018, 03:25 AM
Last Post: in4rit
  Discussion What VTX power setting do you fly with? DannyZ 8 6,608 16-Jan-2018, 02:36 AM
Last Post: sirdude
  Discussion Thunder Power Adrenaline 2600maH Battery for Taranis DannyZ 0 834 17-Jun-2017, 04:20 PM
Last Post: DannyZ
