Thunder Power Adrenaline 2600maH Battery for Taranis
Has anyone used the Thunder Power 2600Mah Battery for their Taranis ?
I ordered one the other day, but as I was trying to fit it into the battery bay, it is a VERY tight fit and the battery actually seems to put a fair amount of pressure on the connector where it plugs into the Taranis board,
Or does the bay need to be modified so there is more clearance between the battery and the connector ?
Thanks
Danny
  Quad won't Arm Low Power Mode Unable to record videos Seanalami 3 550 27-Mar-2022, 11:13 PM
  Plug in quad to the battery and it shut down afterwards Femstar 3 354 18-Nov-2021, 09:39 PM
Last Post: Femstar
  Solved Taranis X9 Lite models Krayon70 3 432 01-Aug-2021, 07:36 PM
Last Post: MrSolo
  Help Parallel Battery Adapter qcumbercool 2 378 12-Aug-2020, 01:04 AM
Last Post: qcumbercool
  SD CARD ERROR expected version 2.2v0016 taranis x9d IrishFlight 2 5,077 29-Mar-2019, 02:00 PM
Last Post: IrishFlight
