Betaflight setup howto (Eachine Racer CC3D)
Hi, I've got an eachine racer CC3D and I am trying to update from Betaflight v2.1.6 to v2.9.0, but I don't seem to get it to work. Everything worked fine with my current setup but I was just curious about the newer versions.
What I did:
- Flashed betaflight through librepilot
- Disabled oneshot
- Calibrated esc's
- Applied mmix's
- Set CC3D yaw -90°
What am I missing? It is jumping around like a fool, but not flying?
as I learn many point that can cause a problem.. must check propeller direction, whats new after the last update need setting new PID or can use last PID, calibrated gyro/acc compass GPS (if any)
dont forget default mode.. I just experience default acro mode cant fly well cause no self level at all on quad, try horizon or angle mode
Can you post a CLI-dump?
  CrossFire Connection Issues-Radio Master Zorro- No Betaflight input Apex FPV 3 147 06-May-2024, 02:35 PM
  BetaFlight Connection Issues..... Coleon 17 698 02-Apr-2024, 12:26 PM
  Need recommendation for FPV setup butchalline 7 192 24-Mar-2024, 02:35 PM
  Betaflight 4.4.3 on Speedybee F4V4 Ladu 4 257 14-Mar-2024, 04:45 PM
Last Post: Ladu
  Nanofly 16 setup Boi 2 173 29-Jan-2024, 07:24 AM
Last Post: Boi
