Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 2
0 Hi,
I'm using Betaflight 4.4.3 on Speedybee F4 V4 FC. I've setup 'Arming' to Aux 1 of the controller. But as soon as I Arm, the motors start spinning rather pretty fast, instead of start to spin with the throttle. Need help to fix this.
TIA
Threads: 581
Likes Received: 8,918 in 6,598 posts
Likes Given: 1,425
786 If you are testing the motors with props off on the bench then that behaviour is completely normal and is to do with the PID controller detecting no expected change in attitude of the quad as the motor RPM is raised, so it keeps raising the motor RPM higher and higher to try and get the quad to lift off the ground because it thinks there isn't yet enough thrust to do so which is why your motors can appear to behave erratically or spin up to max RPM by themselves. Have a watch of the following video to understand why. To get proper behaviour you need to put the props on and take it outside for a hover test. You will then find that the motors behave as commanded by your transmitter.
Threads: 18
Likes Received: 47 in 44 posts
2 If, on the other hand, the motors spin up with the props mounted, it could be a problem with motor vibration getting into the FC through the frame.
If you test the motors with the props mounted, ALWAYS hold onto the drone by hand.
I had this problem with a 2S build on a too-flexible frame. Upon arming with throttle at minimum it wanted to shoot to the moon. The solution was to add some rpm filter by moving both sliders to the left, from 1.0 to 0.8.
The better solution was to throw away that frame and use a stiffer one. Filter back to 1.0, and it flies well without firing for the moon.
