Tinywhoop problem
I have the betafpv acvanced Kit 2 with the meteor 75s. So, my whoop doesn‘t even connect to my Literadio 2 se anymore... When I power it up, it does the usual sounds ( dee dee dee, dee dee dee, dee deeeee) that’s the sound it makes when the binding is successful. But now my whoop just keeps blinking yellow constantly and doesn’t connect to my transmitter. I tried connecting it to betaflight but I can’t really connect it (but that’s another problem). Does anyone have a solution for that?? Thanks, Marc.
Hi Marc,
Have you tried re-binding the quad and the transmitter? If not, then try that first.
In connecting it to Betaflight configurator, does the USB cable make a good connection with the quad? If you can get the USB cable connected to the quad and to the computer, does it work when you click "Connect" on the Betaflight Configurator screen. What happens here?
I agree, I would try re-binding first. It is possible that the radio protocol switched. How many times does the LED blink when you turn the controller on? See the section on protocol at this link https://betafpv.com/products/literadio-2...ransmitter
Also, the drone that comes with Advanced Kit 2 runs Silverware and not Betaflight.
[-] The following 1 user Likes ax3141's post:
  • iFly4rotors
Hi Ax,
I didn't realize that the transmitter was multi-protocol. With that information, I agree that the protocol on the transmitter might have gotten switched.
Also, did NOT know that kit came with Silverware which is Bayang protocol {at least all of my Silverware FCs are Bayang}.
Ohh sorry guys for the late response and thanks again! It’s not bayang protocol, but FR-SKY. When I connect it with my computer to betaflight, and I press connect, it just says open success and 10 seconds later, closed success. And it can’t be the cable, bc I’ve just bought an emax TH s and it connects perfectly with it with the same usb-c cable. So is there any other solutions?
please??
  Hi with a problem :D Lyniix 9 581 25-Aug-2021, 01:47 PM
Last Post: Lyniix
  Tx16s binding problem marc_fpv 8 1,597 26-Jun-2021, 11:56 PM
  binding problem marc_fpv 4 951 25-Jun-2021, 06:52 PM
  Binding problem marc_fpv 1 462 22-Jun-2021, 09:04 PM
  Tiny whoop problem marc_fpv 4 418 06-Jun-2021, 03:34 PM
Last Post: Kuchenz
