Threads: 6
Likes Received: 0 in 0 posts
Likes Given: 2
0 06-Apr-2021, 11:57 AM (This post was last modified: 06-Apr-2021, 11:58 AM by panosth4.) Hi guys, I have a problem with my fathsark dominator v3. I connect the battery and nothing happens. No display no beeping nothing. I dont know what to do please help me.
By the way yes the battery is charged and i have put the antennas on
Threads: 595
Likes Received: 9,037 in 6,688 posts
Likes Given: 1,428
796 06-Apr-2021, 12:01 PM (This post was last modified: 06-Apr-2021, 12:02 PM by SnowLeopardFPV.) Before looking any further, have you measured the output voltage from the barrel connector of the battery with a multimeter to double-check that it is actually producing voltage? If so then what voltage are you getting from it?
Threads: 6
Likes Given: 2
0 Yes both cells of the battery give 4,2 volt each if that is what you mean
Threads: 6
Likes Given: 2
0 06-Apr-2021, 12:09 PM (This post was last modified: 06-Apr-2021, 12:09 PM by panosth4.) Is there any other way to see that i get from the connector bcs i dont have a multimeter
Is there any other way to see the voltage that i get from the connector bcs i dont have a multimeter
Threads: 6
Likes Given: 2
0 but im pretty sure its not the battery bcs i have tried it with some other goggles and it worked
Threads: 6
Likes Given: 2
0 06-Apr-2021, 12:13 PM (This post was last modified: 06-Apr-2021, 12:13 PM by panosth4.) and if it was the connector that had the problem could the battery be fixed or should i just get a new batttery
Threads: 595
Likes Given: 1,428
796 The cable with the barrel connector on is a known weak point on the battery case. It's possible it has an intermittent connection due to a broken wire inside the cable. Make sure that definitely isn't the case by measuring the voltage from the barrel connector while wiggling the cable about. You should get a constant ~8.4V with two fully charged batteries in the case.
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 06-Apr-2021, 12:59 PM (This post was last modified: 06-Apr-2021, 12:59 PM by Kevin2112.) I made a tutorial on how to fix. look back in my threads it’s the 3rd one I wrote. I’d post it here for you but do not know how to. I need to learn that. It can still be bad even if it works sometimes. Do not use the battery case until you get it fixed or replaced. Search for “fat shark barrel connector”.
Threads: 63
Likes Received: 93 in 70 posts
Likes Given: 26
1 I bet is the barrel connector. I gone thru like 3 Fatshark battery packs.
Threads: 6
Likes Given: 2
0 sorry for not responding I checked the battery and its ok and works fine with other goggles
Threads: 6
Likes Given: 2
0 i also opened my goggles and they seemed ok no smoke nothing smelled like it was burnt
Threads: 595
Likes Given: 1,428
796 In that case something on the power board has probably just gone bad. Check the solder joints around the barrel connector socket for any cracks or to see if it has come away from the board. Also check any cables plugged into the board. Failing that, FatShark is renowned for having excellent aftersales customer service with service & repair centres on most of the big continents, so I would contact FatShark support and then get them sent to a repair centre.
Threads: 6
Likes Given: 2
0 06-Apr-2021, 04:42 PM (This post was last modified: 06-Apr-2021, 04:43 PM by panosth4.) i cant send them to fathsark because i have already sent them 1 time
so im not allowed for more
should i buy a new power board and install it or not?
