Fatshark HD3 gray-ish screen
So i bought a pair of used fatshark hd3's. They were working perfectly woth laforge module. Today i was trying to take the goggles apart and run the laforge wire through the goggles. (previously it was running from outside) Now when powering up my goggles, the screen is just gray, no static. Its most definetly not a power issue since the buttons work. And also the the module wont turn on
There are some delicate cables running between the two parts of the goggle shells including a ribbon cable in the middle. You can see some of those cables in a pair of HDO goggles in another post HERE.
I suggest you open up the goggles again and make sure you haven't damaged any of the cables and that the connectors on both ends of all the cables are seated properly in their sockets by carefully unplugging and re-plugging the connectors to re-seat them.
Did u find a solution?
  Help OSD Working but Grey Screen Caelus_fpv 4 384 25-Apr-2024, 03:14 PM
Last Post: Caelus_fpv
  Can FS HD3’s be repaired? husafreak 11 439 29-Mar-2024, 03:58 AM
Last Post: husafreak
  Burned MOSFET on Fatshark HDO2 necbot 8 627 13-Mar-2024, 05:03 PM
  Black screen and no OSD: Eachine TX06 + EV800 + DarwinFPV F411 Ultralight/Whoop AIO aprudnikoff 1 287 05-Mar-2024, 09:18 PM
  Help Fatshark hdo2 turns off at 7.8v konfuzuyyus 16 847 27-Nov-2023, 01:28 PM
