Wiring up a TBS vtx question? Help
So as over the year have built up my kwad myself,friend alway seem to help with the Pc config stuff,but he's not about anymore so need to start learning so here goes...
Soldering a vtx in the picture I have green and white left.
Do I solder the white to tx 6
And use smartaudio or config it in crossfire am abit confused?
Can I cut the green off, someone needs to help with what smartaudio does?
Thanks in advance
Can't get picture up?!
Yellow wire to vtx on FC
Red to 5v-9v can't remember as needs more than 5v to work sorry am new to this
How to upload pictures to the forum -> https://intofpv.com/t-how-to-upload-pictures
Make sure you are viewing the forum in desktop view. If you are viewing the mobile version, scroll all the way to the bottom and click on the "Switch to Full View" link. You can switch back to the Mobile Version again if you need to after posting the images.
Thanks will but a picture up just realised the white wire is going to crossfire Rx am I right
Here is the picture hopefully
You sure that's wired up right? It looks like things are wired in the following configuration assuming this is a Kakute H7.
FC       -> VTX
Vid out -> Bat
Bat      -> Gnd
Gnd     -> Vid in
Just the 3 wire on a f7 FC
Red to battery positive
Yellow to VO video output
And black to GND.
Alright, that makes a large difference. Without the flight controller model listed, I had to guess. Looks extremely similar to the one I'm using.
But yeah, if you plan to use SA, you can simply remove the green wire. Just pop the white wire onto a free UART TX pad and set that as VTX (TBS SmartAudio). The green and white are used if you wire directly to a TBS RX module. Voltage range is 6-25 volts, so 2-6S, which that pad should supply.
Thanks very helpful ? Now onto the crossfire Rx that should be alot easier to solder/wire up.
Hope you have success! In my opinion, that's the best 5.8GHz analog VTX, and the best proprietary control link. Should serve you very well!
Do let me know if you have troubles getting the VTX unlocked for full power. That info is strangely uncommon, despite being a requirement to get the most out of the device.
  Any explanation for smoke coming out of my walksnail VTX? zelando 59 4,623 Yesterday, 09:21 AM
Last Post: Cake
  GPS wiring question sdtrent 15 3,779 10-Apr-2024, 08:58 PM
Last Post: oleg.andreychenko
  TBS Fusion, wiring buttons ... Red_ran 0 122 25-Mar-2024, 02:30 AM
Last Post: Red_ran
  ELRS Rx to FC with only 3 wires question husafreak 12 450 10-Mar-2024, 02:33 AM
Last Post: husafreak
  Tbs m8-2 gps does not light up in bf konfuzuyyus 3 286 05-Dec-2023, 04:06 PM
Last Post: RC Randy
