Threads: 5
Likes Received: 1 in 1 posts
Likes Given: 6
0 Hi there. Trying to setup my gps m8-2, all wired up correctly, and the power led lights up. But there is no gps light up in betaflight.
Tried an other gps module (gm10) and it works perfectly fine.
Set baudrade to 9600 which is default.
Any ideas?
Threads: 125
Likes Given: 99
388 Try increasing baud width higher.
If you are wiring it the same way as you gm10 and it still doesn't work, it likely the GPS unit is bad.
Threads: 0
Likes Received: 0 in 0 posts
0 Did you ever find out what the problem was? I'm having problems with that same gps module.
