03-Feb-2016, 10:25 PM (This post was last modified: 03-Feb-2016, 10:28 PM by Jordan Marinov. Edit Reason: spelling )
Hey guys, just finished a build QAV180, LittleBees 20A, Naze32 Rev6, TMotor 1806 test samples. Running with HQ 4045BN and 4S. I am noticing a weird vibration pretty much at all times during flight. It is not big and does not get worse with maneuvers or throttle. I'm running Betaflight 2.1.6.
Here is what I tried:
Here are the pids on the last LuxFloat tune:
set pid_controller = LUX
set p_pitchf = 1.800
set i_pitchf = 0.500
set d_pitchf = 0.010
set p_rollf = 1.400
set i_rollf = 0.500
set d_rollf = 0.008
set p_yawf = 4.000
set i_yawf = 0.550
set d_yawf = 0.006
Any ideas are much appreciated.
- Default PIDs on MultiWii rewrite - blackbox log
- Default PIDs on LuxFloat - blackbox log
- Fresh set of 4045BN props
- Drop dterm_cut_hz from 40 to 30
- I've tuned LuxFloat to lower P, lower D (much lower to what I normally run) and higher I - blackbox log
set p_rollf = 1.400
set i_rollf = 0.500
set d_rollf = 0.008
set p_yawf = 4.000
set i_yawf = 0.550
set d_yawf = 0.006
