Hi Rosssiiii,
Here is my take on it...
Small ( 2 inch or less ) tiny whoops are great for indoors. You can fly them around the house and have a lot of fun.
Now, there seem to be a lot of new open prop offerings in the 40mm to 2 inch range..1S or 2S;
like the Flywoo in your post. So...one of these might be a good choice.
If you don't need to have "whoops" or prop guards, then you might consider the GEPRC Phantom, the EMAX TinyHawk
Freestyle II, the Crux3, or something similar. If the quad is a 2.5 or 3 inch, you can run the new turbine style props
{5 blade or 6 blade} such as these
HQProp T63mm X 6 Hexa-blade props. This prop will fit a 2.5 inch quad (or a 3 inch).
These turbine style props are "quiet" when compared to the standard bi-blade and tri-blade props.
Although I have not specifically performed testing, a quad running these new turbine style props might actually be
quieter than a small whoop...less likely to be heard or noticed.
I have both an EMAX TinyHawk Freestyle and GEPRC Phantom (I have bought 2 of these and build a clone).
These are both 2.5 inch open prop quads that I purchased with the FrSky receiver (BNF). Since I don't consider
the 2.5 inch to be a long range quad, the XM+ receivers work well for me. Both are fun to fly and they
perform pretty much the same.
I prefer the GEPRC Phantom because it has standard 4 bolt motors, a non-integrated FrSky XM+ receiver,
and the frame will accept standard 16x16 stacks (or AIO) or the 26x26 whoop AIO FCs. For me, these features
make the quad much more repairable and upgradable. The Phantom frame is remarkably versatile and can be
used for a variety of configurations.
{NOTE: I have several builds based on this frame}.
Although I like flying the EMAX TinyHawk Freestyle, the FC board is a propriety
{non-standard} mounting format
and it has the receiver built into the board...and... has 3 bolt motor mounting pattern which I really do not prefer.
{the 3 bolt motor mounting pattern is used on the smaller motors meant for whoops}. For me, the FC board can
easily be replaced with a standard FC using a mount plate...no big deal. On the other hand, the motors being a
3 bolt pattern presents quite a different issue since all of my motors have the 4 bolt pattern. Yeah, I could use a
small mount plate or even full arm "overlays"; both are quite workable, but just adds another layer of complexity.
Now, I am not going to buy motors with a 3 bolt mounting pattern since I would only be able to use them on the
EMAX TinyHawk frame. Even my 2 inch whoops have 4 bolt motor mounting.
{yeah, I already have plenty of tiny whoops that I can fly inside the house. Plus I have plenty of parts for repairs}.
