23-Nov-2023, 04:03 PM
I am using BF 4.4.3 VTX presets with Rush Tiny Tank and OSD shows R8 but practically the signal is only on F7 , no matter what I do. I tried MSP with Display port as well as Smart Audio in Ports tab.
Rush tiny tank only F7 ?! |
23-Nov-2023, 04:03 PM I am using BF 4.4.3 VTX presets with Rush Tiny Tank and OSD shows R8 but practically the signal is only on F7 , no matter what I do. I tried MSP with Display port as well as Smart Audio in Ports tab. 23-Nov-2023, 05:11 PM Sounds like the VTX Table is incorrect. Change the VTX to match the table below. There are a bunch of pre-set table in the GUI. Otherwise you just have to manually enter it. 23-Nov-2023, 08:54 PM It sounds like the ELRS transmitter controls the video transmitter. Still the same , VTX is F7, and OSD shows R8. The table is updated 23-Nov-2023, 08:56 PM OK, I don't think you have VTX control properly setup. Let's check your wiring. Photos of your wiring from VTX to FC. Post dump file. And what radio controller do you have? I have RM Zorro, see wiring and cli dump below. # # diff all # version # Betaflight / STM32F411 (S411) 4.4.3 Nov 14 2023 / 17:22:54 (738127e7e) MSP API: 1.45 # config: YES # start the command batch batch start # reset configuration to default settings defaults nosave board_name BETAFPVF411 manufacturer_id BEFH mcu_id 0037005e503150122034344e signature # name: Race1 # feature feature -TELEMETRY # serial serial 1 2048 115200 57600 0 115200 # beacon beacon RX_LOST beacon RX_SET # aux aux 0 0 0 1700 2100 0 0 aux 1 1 1 1300 1700 0 0 aux 2 13 2 1700 2100 0 0 aux 3 35 1 1700 2100 0 0 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BAND_A A CUSTOM 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BAND_B B CUSTOM 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BAND_E E CUSTOM 5705 5685 5665 5645 5885 5905 5925 5945 vtxtable band 4 AIRWAVE F CUSTOM 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R CUSTOM 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable band 6 LOWRACE L CUSTOM 5362 5399 5436 5473 5510 5547 5584 5621 vtxtable powerlevels 4 vtxtable powervalues 14 20 23 25 vtxtable powerlabels 25 100 200 350 # master set gyro_lpf1_static_hz = 275 set gyro_lpf2_static_hz = 550 set dyn_notch_count = 1 set dyn_notch_q = 500 set gyro_lpf1_dyn_min_hz = 275 set gyro_lpf1_dyn_max_hz = 550 set acc_calibration = -48,-63,-9,1 set blackbox_sample_rate = 1/2 set dshot_idle_value = 600 set dshot_bidir = ON set dshot_bitbang = ON set motor_pwm_protocol = DSHOT300 set motor_poles = 12 set vbat_max_cell_voltage = 435 set yaw_motors_reversed = ON set small_angle = 180 set pid_process_denom = 1 set simplified_gyro_filter_multiplier = 110 set osd_tim1 = 2562 set osd_vbat_pos = 2369 set osd_rssi_pos = 226 set osd_link_quality_pos = 2061 set osd_rssi_dbm_pos = 2069 set osd_tim_1_pos = 2232 set osd_tim_2_pos = 2264 set osd_flymode_pos = 2450 set osd_throttle_pos = 5 set osd_vtx_channel_pos = 2080 set osd_craft_name_pos = 2443 set osd_pilot_name_pos = 2437 set osd_warnings_pos = 14729 set osd_avg_cell_voltage_pos = 2337 set osd_canvas_width = 30 set osd_canvas_height = 13 set vtx_band = 5 set vtx_channel = 8 set vtx_power = 1 set vtx_low_power_disarm = ON set vtx_freq = 5917 set gyro_1_sensor_align = CW90 set gyro_1_align_yaw = 900 set serialmsp_halfduplex = ON set craft_name = Race1 set pilot_name = Irek profile 0 # profile 0 set p_pitch = 56 set i_pitch = 60 set d_pitch = 53 set f_pitch = 143 set p_roll = 54 set i_roll = 57 set d_roll = 46 set f_roll = 138 set p_yaw = 54 set i_yaw = 57 set f_yaw = 138 set d_min_roll = 43 set d_min_pitch = 48 set motor_output_limit = 86 set feedforward_averaging = 2_POINT set feedforward_smooth_factor = 45 set feedforward_jitter_factor = 9 set simplified_master_multiplier = 115 set simplified_i_gain = 60 set simplified_d_gain = 125 set simplified_pi_gain = 105 set simplified_dmax_gain = 25 profile 1 profile 2 profile 3 # restore original profile selection profile 0 rateprofile 0 rateprofile 1 rateprofile 2 rateprofile 3 # restore original rateprofile selection rateprofile 0 # save configuration save # 24-Nov-2023, 09:43 PM Hi niuk, Try to confirm the pulldown options in your BTFL VTX preset. The "show CLI" table for TinyTank does not have Lowrace available, thus only 5 bands in the CLI. The diff you posted might be for one of the Race Tank versions. I could only verify that none of the reviews or sales literature describes the lowband feature but it is "greyed-out" as available on request. Might be worth a shot?? 25-Nov-2023, 07:19 AM Again. Dump file. Not diff. Photo of how you wire, not a diagram from the manufacturer. Trying to figure out whether you did something wrong. 25-Nov-2023, 02:32 PM 25-Nov-2023, 06:35 PM |
Looks like i have some issues on the tiny whoop motor | Rosssiiii | 24 | 1,400 | 02-Feb-2024, 02:20 AM Last Post: [email protected] | |
rush tank 2 ultimate wiring help to argus f7 pro | Dice | 1 | 168 | 21-Jan-2024, 12:09 AM Last Post: matt0725 | |
RUSH TANK power level light | tommy g | 9 | 5,612 | 13-Jan-2024, 06:21 PM Last Post: swequad | |
How to connect Rush Tank Ultimate 2 to Omnibus F4 AIO | icoryx | 1 | 221 | 08-Oct-2023, 04:36 PM Last Post: Rob3ddd | |
Rushfpv solo tank and smoke stopper issues | jfe | 2 | 214 | 08-May-2023, 10:42 AM Last Post: jfe |
