Threads: 15
Likes Received: 3 in 1 posts
Likes Given: 43
0 Hey guys! I’m having trouble taming the throttle on the little sucker. I’ve tried scaling the throttle down in BetaFlight, haven’t tried clipping yet. It feels like I have control the first 20% of the stick but then any more throw than that and it wants to punch upwards. I’m sure I need more practice on it but I’d appreciate any advice from you guys. Shoot, I’ve only been a member for a few hours and after reading SnowLeopardFPV’s advice I know there are some real aces out there. Thanks!
Threads: 118
Likes Given: 128
20 If ur on 2s .. fly it on a 1s
Threads: 118
Likes Given: 128
20 Yeah.. that controller isn’t the greatest. Good news is WHEN you upgrade that component.. u have a price range from $30-300...with a lot of good information Ron to make a educated decision..
You can change the throttle 2 ways. One in the PID tab(bottom percentage).. or the throttle
Threads: 31
Likes Received: 82 in 67 posts
4 Are you flying indoors? If so, that's very challenging even for the TH2 as a beginner. I've been there - the TH2 was my first quad. Maybe move outdoors where you have more room?
What radio are you using? If it is the junky one from Emax, they can jitter like crazy, making throttle control difficult. Connect the TH2 to the computer and look at the receiver tab in Betaflight. Is the throttle smooth as you move the left stick? Mine jumped all over the place. I eventually put that controller in the trash and got a better radio.
Threads: 2
Likes Received: 0 in 0 posts
Likes Given: 1
0 I concur with what Ljholland says. The Emax E6 radio is really jittery especially in the middle. I found that pushing in the throttle stick or twisting it a bit would help for a few minutes.
I’m an absolute beginner and haven’t successfully flown my TH2F yet, but in the simulator I absolutely had the same problem as you describe.
Threads: 15
Likes Given: 43
0 I’m really impressed with the feedback I’ve gotten so far. Thank you guys! Hey crepitus, are you flying the stock rates?
Threads: 118
Likes Given: 128
20 Let me get my THs info.. it files indoor like it’s no ones business !
Threads: 118
Likes Given: 128
20 Ok.. posting pics here is kinda PITA.. so this is what I have.. I fly this inside in angle mode.. the “angle limit” is 25degrees, you can increase it if u want.. but I can fly it with the pitch stick all the way forward..
Betaflight 4.0.0
P. I. D. FF
ROLL. 100. 120. 90. 90
Pitch. 100. 120. 90. 90
Yaw. 90. 90. 40. 80
Angle / horizon
Strength. Transition
Angle 50
Horizon 50. 75
Angle limit
25
Basic / ACRO rates
RC Sr. RC expo. Max vel.
80. 60. 60. 400
80. 60. 60. 400
80. 60. 20. 400
DShot 300.
Gyro. 4.0 kHz
PID loop. 4.0khz
*NOTE. The “.” After the numbers (PIDS /Rates) were put in by my phone .. so the placement in betaflight should remain
Keep me posted .. I honestly have NO IDEA how or where I got these.. but it has made flying my tinyhawk inside SO MUCH MORE enjoyable !
