28-Feb-2021, 02:42 AM
https://team-blacksheep.com/products/pro...odraceraio
aio as mount board to solder nano rx and unify pro32 directly, pretty clean :-)
tbs-aio |
28-Feb-2021, 02:42 AM https://team-blacksheep.com/products/pro...odraceraio aio as mount board to solder nano rx and unify pro32 directly, pretty clean :-) 02-Mar-2021, 02:51 PM Hi Bat, Yeah, I saw this one. It is a very compact set up. If I had TBS Crossfire gear, then I would definitely be interested. The only concern is using SoftSerial for the GPS, but I guess it might be fast enough. 02-Mar-2021, 03:11 PM soldered it yesterday, the hifionrc f7 20a have the direct mount too for nanorx and unify pro32, its huge board like a 30x30mm electronics. sadly there isnt even an led pad to use softserial, f7 but no pads to use more than two uarts what a board xD hopefully its better in other disciplines :-) the fets looks huge, this might be good. 02-Mar-2021, 03:50 PM Hi Bat, Exactly which HIFIONRC F7 20A FC do you have? Do you have a good picture of it. Is it a whoop format AIO? ..or.. some other mounting format? All of my F7 FCs have plenty of UARTS. I have the HIFIONRC F7 25A 26x26 whoop format in a couple of quads with GPS and SmartAudio. In fact, I don't even use UART 3,4,5. I have attached a picture of the HIFIONRC F7-25A board that I use. 02-Mar-2021, 07:01 PM (This post was last modified: 02-Mar-2021, 07:04 PM by hugnosed_bat.) this one, 25mm aio mount but outside diameters are big. it has vtx and rx pins as pads and to mount pins, nothing else 02-Mar-2021, 07:24 PM (This post was last modified: 02-Mar-2021, 07:26 PM by iFly4rotors.) Hi Bat, Sorry, but the images are so blurry that I can't read them. I tried saving the image, but it is still too burry for me to read. I do know that using that "Imgur" thing reduces the resolution especially for larger files. This is one reason that I use attachments, it holds the resolution. Now, there is a size limit which means either splitting the graphic such as the one you posted into individual files, resizing the picture in your graphic program of choice, or just cropping them down. If your file is not too large, you could try adding it as an attachment and see if that works. Otherwise, it might need to be split apart. Thanks P.S. Do you have website links for the FCs ? 02-Mar-2021, 07:28 PM 02-Mar-2021, 09:27 PM Hi Bat, Can you post a screen shot of the Betaflight "PORTS" for this FC ?? Thanks 02-Mar-2021, 09:32 PM i can in a few days, soldered it for a buddy. will meet him next week, hopefully he will get the motors until than :-) 02-Mar-2021, 10:14 PM I wish they would make a 1S AIO with integrated Crossfire and a 25mw VTX. 02-Mar-2021, 10:26 PM 03-Mar-2021, 11:50 AM Take close look at that board. What is the labeling on the TBS Nano through holes? Is that T5-R5 or T3-R3 ?? {I can't tell}. If that they are both labeled as T5-R5, then probably parallel wired {together}. I have gone through all of the CLRACING F7 boards... all of their other F7 boards have exposed the extra URTS. In fact, this is the only F7 board that I have seen where extra UARTS were not exposed. 03-Mar-2021, 01:18 PM yes, here too. didnt saw any f7 board with that low number of uart pads 03-Mar-2021, 06:22 PM Whoa I just got an email from Raphael when I sent them a suggestion on the integrated Crossfire. He said they will be revisiting it because evidently, "last time there was just too much "bickering" between F4, F7, H7." |
FC (2nd) Cheapest F4 AIO FC | romangpro | 4 | 759 | 11-Dec-2023, 01:33 AM Last Post: romangpro | |
FC Flywoo AIO 12A with 400mw vtx and ELRS | romangpro | 8 | 597 | 08-Nov-2023, 08:10 PM Last Post: Pathfinder075 | |
TBS is back!?! | skywanderer | 20 | 1,692 | 27-Jul-2023, 06:03 AM Last Post: ph2t | |
VTX tbs crsf/tracer - 1w vtx combo board for 49$ | hugnosed_bat | 25 | 3,584 | 02-Apr-2022, 11:53 AM Last Post: kafie1980 | |
Latest TBS Agent M app: Telemetry viewer and GPS logging | kafie1980 | 12 | 3,016 | 20-Feb-2022, 03:07 PM Last Post: kaitylynn |
