  • 1 Vote(s) - 2 Average
Taranis Telemetry same time Microsd Vbat Naze32
Good morning to all,
i need to clear one doubt and no one has give me an answer on mini quad group ou in my portuguese group. I was using spektrum and had VBAT monitor to Micromosd (i have on screen voltage, status (armed or disarmed) and i could tune my pids on the quad by stick.
I changed to taranis, i connected the telemetry pins to d4II and activated telemetry on naze FRSky.
Now i have taranis singing voltage and information when armed. Ok...
BUT i lost osd information, battery is valued is freezed, does not recognize when i arm it (keeps disarmed on screen) and also i cant enter on PID tuning menu. The flight modes change on screen when i switch on taranis, so its communicating, but voltage, sticks nothing happens.
Is it possible to have at same time taranis information voltage and the microsmosd ?!?!? How ???
Are you reading voltage from the FC, or on the minimosd?
Do you have timer on OSD as well? Does it work during flight?
What UART do you use for the minimosd?
And verision of the MWOSD and your clean flight?
1 - From FC - i have directly the wires from the batt to the batt pins on FC and Vbat
2 - Timer works
3 - Not at home... but i think i dont have any uart configurated to... where can i see and example of micromosd and frsky telemetry ports configuration ?
4 - R1.4 Pre 1.3 - Cleanflight i am using Betaflight 2.3
when i had spektrum worked Smile -
So it sounds like your FC isn't talking to your MinimOSD properly.. I don't know if it's the protocol has changed in latest clean flight... Or something else..
If it's not too much trouble could you try flashing it with a previous version maybejust for testing?
(23-Feb-2016, 02:15 PM)Oscar Wrote: So it sounds like your FC isn't talking to your MinimOSD properly.. I don't know if it's the protocol has changed in latest clean flight... Or something else..
Think i found the problem !!!
And the solution !!! As i suspected... "not" possible to use both outputing.
http://quadquestions.com/blog/2015/08/27...ky-d4r-ii/
Confirmed. Done. Pin 6 solved.
My taranis folder with notes, prints and my configuration - https://www.dropbox.com/sh/h1mxlggx8qpe6...GeqWa?dl=0
Thanks Ricardo didn't know it's possible hehe thanks for sharing!
Yep, you need to enable telem for frsky usin a softserial.
Good you found the solution, I have that same page bookmarked. LOL
Happy flying!
BTW, sometimes you need to do: set telemetry_inversion = on
No clue why, I have 2 Naze32 and one needed it, the other didnt.
https://github.com/cleanflight/cleanflig...lemetry.md
  tango 2 no telemetry screens cele_FPV 6 136 25-Apr-2024, 10:48 PM
  Crossfire diversity wrong telemetry data noize 15 1,813 22-Mar-2024, 06:21 AM
Last Post: Myman
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 218 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  No GPS telemetry data on my crossfire tx PJKMBAKER 3 662 11-Oct-2023, 12:04 PM
  Taranis & TD 100 [km] zomer 0 198 03-Sep-2023, 03:27 PM
Last Post: zomer
