31-Jan-2024, 01:15 AM
I have a BetaFPV ELRS 2.4 Ghz 1 W module in the back of my Taranis X7. I had troubles getting it to flash, which may be the problem. I've follow the instructions but get a failed message. It said to submit the log file but I didn't see one. When I power the Taranis on the display on the module says Ver 2.5.1, so it may be OK.
I've configure the Taranis as best I can by following some direction on a YouTube, then on the Taranis I go to the Tools menu, select ExpressLRS and press the button to load the lua script, all I get is a message that says "Loading" but nothing else happens. I did load the lua script onto the SD card.
What am I doing wrong?
Thanks
Thanks
