07-Oct-2021, 09:00 AM (This post was last modified: 27-Jul-2023, 09:59 AM by psicho100pro.)
Do you like new things in old packaging? This is for you,,,,
Credits
>>> https://github.com/OpenI6X/opentx <<<
For FlySky i6 owners there is another similar solution Kotello's ER9X
Good luck pilots! 100p
- AFHDS2A with SBUS, IBUS
- extended SBUS16, IBUS16 - 16 channels modes + LQI at channel 17
- receiver ID support
- failsafe warning
- PPM in/out
- CRSF with ExpressLRS and Crossfire modules
- CRSFshot
- MEGA Bauds up to 1.8
- ExpressLRS 3.0 compatibility (lua port)
- "Other devices" functionality
- Multiprotocol telemetry, up to 30 sensors
- AUX Serial
- port available telemetry mirroring via BT to Telemetry Viewer
- SBUS Trainer
- Debug (on DEBUG builds)
- Audio tones, alarms and vario custom implementation
- Adjustable backlight brightness
- DFU bootloader like regular OpenTX one
- USB Joystick & Storage modes on standard cable
- Mass Storage to backup/restore eeprom
- Multilingual builds
- Other backports and minor changes
- Experimental INAV screen
Credits
- Janek (ajjjjjjjj), continues Kuba's and Mariano's work, added sound, USB, ExpressLRS V2/V3 configuration, telemetry mirror, SBUS trainer, new/fixed drivers, ports, bugfixes.
- Mariano (marianomd), continued Kuba's work and made it up to useable condition! Added AFHDS2A, PPM, CRSF.
- Kuba (qba667), started this work and made this project possible, it is forked from his repo.
- Wilhelm (wimalopaan) added 16 channels SBUS16 / IBUS16 modes.
- Tom (tmcadam) fixed AFHDS2A PWM mode selection.
- The internal RF code was taken from the great KotelloRC's erfly6: Er9X for i6 and i6x.
- Some of the internal RF fixes are a result of analysing pascallanger's DIY-Multiprotocol-TX-Module.
- ExpressLRS configurator is based on elrsV2/V3.lua from ExpressLRS.
- Some of the ports are from EdgeTX.
- ADC code taken from OpenGround.
- All the contributors of OpenTX.
