01-Mar-2024, 09:46 PM (This post was last modified: 05-Mar-2024, 04:48 PM by aprudnikoff.)
I'm building my first FPV and experiencing some issues connecting my radio to FC.
Some words about my setup:
FC: Darwinfpv 15A 1-3S F411 Ultralight/Whoop AIO https://darwinfpv.com/products/darwinfpv...8399501487
Radio: Jumper T-Lite V2 ELRS
Receiver: ELRS Mini https://www.aliexpress.com/item/10050059...caa4tNMyNw
But... I don't receive any input from the radio in the Betaflight's "Receiver" tab. I went through all official setup checklists, troubleshooting pages, google requests and still no luck here. What can I do else? Is there any way to check where's the issue: receiver, FC, firmware, config? Is it something with hardware or software?
- I soldered everything. rx -> tx, tx -> rx.
- Flashed latest Betaflight (4.4.3) to FC. Here I had issues initially. Official FC website says "BetaFlight target: MATEKF411". When I flashed it for that target I got no gyro, no accel, no motors control, maybe some other unidentified issues. When I flashed for target DARWINF411 I started seeing gyro, accel and could control motors. Everything (?) works fine now.
- Flashed latest EdgeTX (2.9.4) and ELRS (3.3.2) to radio.
- Flashed latest ELRS (3.3.2) to RX. Used all recommended options and custom binding phrase equivalent to radio firmware.
- I bound radio with receiver. I may say it's successful. When I power up both led on the receiver goes solid and also I may switch it to wi-fi mode from the radio.
- In BetaFlight I have the following config:
Ports -> UART1 -> SerialReceiver -> Receiver mode = Serial (via UART)Receiver -> Serial Receiver Provider = CRSFReceiver -> Telemetry = onReceiver -> RSSI_ADC = offReceiver -> RSSI channel = disabled
