Sudden fall, strange logs.
Dear colleagues.
I can not understand the reason for the sudden drop. The first case:
Log, video
The second case:
Log, video
# BetaFlight/SPRACINGF3 2.5.4 Mar 23 2016 / 00:47:46 (391dad4)
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature ONESHOT125
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map TAER1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
aux 0 0 0 1625 2100
aux 1 1 1 1875 2100
aux 2 12 3 1675 2075
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 2 900 2100 12 2
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set min_check = 1040
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1150
set max_throttle = 1850
set servo_center_pulse = 1500
set use_oneshot42 = OFF
set use_multishot = OFF
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set serialrx_provider = SPEK2048
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_pitch = 180
set align_board_yaw = 45
set gyro_lpf = OFF
set gyro_sync_denom = 8
set gyro_soft_lpf = 60.000
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 6
set yaw_deadband = 6
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set acro_plus_factor = 30
set acro_plus_offset = 40
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = OFF
set gimbal_mode = NORMAL
set acc_hardware = AUTO
set acc_lpf_hz = 10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set baro_hardware = AUTO
set mag_hardware = AUTO
set mag_declination = 0
set pid_process_denom = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SERIAL
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# profile
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 300
set dterm_lpf_hz = 0.000
set dterm_average_count = 4
set p_pitch = 54
set i_pitch = 40
set d_pitch = 22
set p_roll = 42
set i_roll = 40
set d_roll = 18
set p_yaw = 90
set i_yaw = 50
set d_yaw = 0
set p_pitchf = 1.400
set i_pitchf = 0.400
set d_pitchf = 0.010
set p_rollf = 1.100
set i_rollf = 0.400
set d_rollf = 0.010
set p_yawf = 2.500
set i_yawf = 0.400
set d_yawf = 0.000
set level_horizon = 4.000
set level_angle = 4.000
set sensitivity_horizon = 75
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 30
set i_level = 30
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
# rateprofile
set rc_rate = 100
set rc_expo = 70
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 60
set pitch_rate = 60
set yaw_rate = 160
set tpa_rate = 0
set tpa_breakpoint = 1500
# rateprofile
rateprofile 1
set rc_rate = 100
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
# rateprofile
rateprofile 2
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 60
set tpa_rate = 0
# Active rateprofile for profile 0,
# profile
profile 1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set p_pitch = 54
set i_pitch = 40
set d_pitch = 22
set p_roll = 42
set i_roll = 40
set d_roll = 18
set p_yaw = 90
set i_yaw = 50
set d_yaw = 0
set p_rollf = 1.100
set i_rollf = 0.400
set d_rollf = 0.010
set p_yawf = 2.500
set i_yawf = 0.400
set d_yawf = 0.000
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 30
set i_level = 30
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
# rateprofile
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 60
set pitch_rate = 60
set yaw_rate = 160
set tpa_rate = 0
# rateprofile
rateprofile 1
set rc_rate = 100
set rc_expo = 70
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
# rateprofile
rateprofile 2
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
# Active rateprofile for profile 1,
rateprofile 2
The first case looks like a sudden loss of signal receiver, receiver failure or loss of power of the receiver (3.3 v DSMX satellite). But the second time I do I can not explain ...
Setup:
motor dys 1306 4000 kv
ESC  dys XM20a
118 carbon frame  - Owl from Flexrc.
I would be most grateful for any ideas.
If it was a loss of signal, then do you have a failsafe procedure enable? Your beeper if you have one on board it should start beeping that your FC lost signal from the receiver and you will understand if its a loss of signal. Also it would not arm afterwards and only if you power cycle the FC. I also see that you have a failsafe on a switch. Accidentally enable maybe?
(09-Jul-2016, 02:17 PM)Pippos Wrote: If it was a loss of signal, then do you have a failsafe procedure enable? Your beeper if you have one on board it should start beeping that your FC lost signal from the receiver and you will understand if its a loss of signal. Also it would not arm afterwards and only if you power cycle the FC. I also see that you have a failsafe on a switch. Accidentally enable maybe?
Most likely the reason was a faulty FC. A couple of days ago, he finally diedWink order a new controller.
  When an angry Kookaburra helps you sync your gyroflow logs ph2t 1 308 25-Apr-2023, 07:32 PM
Last Post: drumgod
  Strange oscillations a mid throttle... Gow864 9 8,658 15-Mar-2017, 06:22 PM
Last Post: Trail X
  Shrieker, wobbling... BlackBox logs may help. pasaff68 6 1,938 18-Jun-2016, 02:45 PM
Last Post: Oscar
  my black box logs cli and video all tips welcome jack00scarecrow 2 1,093 30-Mar-2016, 07:32 PM
Last Post: jack00scarecrow
  help with my blackbox logs atfanhalim 1 969 27-Mar-2016, 01:28 AM
Last Post: Oscar
