Threads: 40
Likes Received: 18 in 16 posts
Likes Given: 1
1 16-Jun-2020, 06:05 PM (This post was last modified: 16-Jun-2020, 06:11 PM by yammahoppy.) I have the goal to build a sub 250g freestyle type quad. One of my main criteria is to have it be and HD quad. I have been back and forth on which frame to use and cant seem to get a definitive decision made. I am ok with one of the split cameras and am not sure I want a twig type frame to keep the props out of the camera. I like the Airblade Intrepid V2 but am not sure I can get it below 250g if I want to run it on 4s. I would like it be around 220g AUW to allow for the use of an Insta 360 Go in the future....
Any advise from the sages here would be greatly appreciated.
Threads: 125
Likes Given: 99
388 When you say HD, are you referring to the video recording or do mean the FPV feed?
Threads: 40
Likes Given: 1
1 Recording, planning on one of the split type cameras, NOT DJI!!!!
Threads: 30
Likes Received: 41 in 35 posts
Likes Given: 97
1 I'm Loving the DiaTone R349.
Youtube A Mistake is only a Mistake if you refuse to correct your error.
Threads: 40
Likes Given: 1
1 Jasper,
No props in view on the ET 5 and 171 g, is that w/o a battery? If so what battery an what is the AUW on the ET 5. That was mt original plan but wasn't sure if it would make weight.
Threads: 20
Likes Received: 490 in 341 posts
Likes Given: 420
20 Yes, that's without battery. With 850mah 3s, ET5 AUW is 241g.
If you want more speed, 450-650mah 4S should just squeeze in under 250g.
Threads: 392
Likes Received: 3,231 in 1,827 posts
Likes Given: 3,214
101 The Acrobrat Duo (v2 design) was specifically designed for split style HD cameras and have props out of view. My build comes in at 249g on the dot auw with a 650mAh 4s getting about 2.5 min of hard flying with a Runcam Hybrid 4K ...
Threads: 40
Likes Given: 1
1 18-Jun-2020, 09:52 PM (This post was last modified: 18-Jun-2020, 09:53 PM by yammahoppy.) This is kinda where i am leaning on my hopeful future build...
Airblade Intrepid V2 44g ($36.99)
Emax Eco 1404 6000KV 8.6g (34.4g total)not including wire) ($10.99 each)
Caddx Baby Turtle V2 12g ($64.99)
HGLRC Fd445 15.5g ($47.99)
Pands RC VTX5804 Mini X 3g ($16.99)
Propr HQ T3x3 1.25g (5g total) ($5.00)
Total wight of these components is 114g, not sure how much else the other misc components will be. Cost so far is around $217.00. Not sure if it is worth the effort to build myself or just buy a pre-made HD quad......
Thoughts, recommendations ????????
