Threads: 2
Likes Received: 0 in 0 posts
0 09-Apr-2021, 02:55 PM (This post was last modified: 09-Apr-2021, 04:36 PM by connor19.) This might be a dumb question as I'm really new and just got my 5" quad today. While I'm installing the props on the quad and screwed the locknuts on them, I found I can insert my nail in between the props and the locknut. I can spin the props with my hand and the motor won't move. I haven't test flight it yet, as I'm having this question now - should the props be really tightly sitting on the motor? I tried to screw the locknuts really tightly, yet there is still a space between the prop and locknut.
BTW, I bought the pre-build iflight titan xl5, and the props and locknuts came with the box.
Threads: 593
Likes Received: 9,025 in 6,679 posts
Likes Given: 1,428
793 Yes, the props should be tight. You shouldn't be able to hold the motor bell still and then move the prop on the shaft. It sounds like you haven't tightened down the Nyloc nuts enough.
Threads: 38
Likes Given: 430
118 09-Apr-2021, 03:09 PM (This post was last modified: 09-Apr-2021, 03:10 PM by kafie1980.) The height of the hub on the props should match the bottom of the threaded part on the motor shaft. The props should be tight but not too tight else you may crack the prop hub.
If you have tightened the locknuts and still have a gap or the props are rotating freely along the shaft then perhaps the simplest fix is add a washer below the locknuts.
But I am surprised you are facing this problem with the included props and lock nuts on a pre-built quad.
Threads: 125
Likes Given: 99
388 You probably just have not tighten the locknut down enough. If it is the nylon locknut, they are very tight at first and takes a bit of torque to get all the way down. Can you post a photo?
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 Do prop manufactures have an actual torque value?
Threads: 14
Likes Received: 163 in 126 posts
Likes Given: 1
12 You'll get used to the right tightness. When you turtle mode and they instantly come loose your not tight enough, if they stay on their tight enough.
