Trying to load fport to my rxsr as I don't have a second uart for the Telemetry but every time I try to update it I get the led to blink once then the qx7 just goes back to the list of files ! Opentx 2.2 and now 2.2.2 ! Really stuck . Rx isn't dead as will power up and shows the rssi to taranis . Thanks
03-Aug-2018, 02:14 PM (This post was last modified: 03-Aug-2018, 02:15 PM by RENOV8R.)
From Oscar's tutorial on FRSky firmware flashing:
For those with a Taranis QX7, you need to use the “Smart Port” on the bottom of the radio, on the left of the SD Card slot. The pinout is different too, correct pin order is GND, +5V, S.Port going from left to right (SIG pin being closest to the SD Card slot). You can simply plug a servo cable into it.
(03-Aug-2018, 02:14 PM)RENOV8R Wrote: From Oscar's tutorial on FRSky firmware flashing:
All R-XSR comes with a flash cable. What ends up happening is they use it for wiring and end up having to make a flash wire.
