16-Jan-2024, 08:22 AM (This post was last modified: 16-Jan-2024, 03:39 PM by mulapickle. Edit Reason: added solved prefix )
hi everyone,
i was finishing up with building my first drone and for some reason, drone only connects to the radio when on usb. when i connect it to the battery, rx gives the constant green light like its paired but wont pair with the radio at all.
it connects with the radio when i first plug FC with usb cable and then supply the power via battery.
i had a successful smoke test and has set all the possible config via betaflight.
could anyone please tell me what is happening?
any hint is much appreciated ?
btw, my specs are as follows:
Speedybee f7v3 stack with latest firmware
Battery: 1300mah 6s
Dji O3 air unit
Radio: (jumper-t-pro w/ elrs module
Rx: Jumper 2.4GHz ExpressLRS ELRS AION-RX-MINI
thank you
Battery: 1300mah 6s
Dji O3 air unit
thank you
