20-Aug-2022, 02:31 PM
all the elrs receivers i have flashed no problem. Then I bought 8 betafpv 2.4 lite with flat antenna ?? any tips?
can not flash betafpv elrs lite v1.1 flat antenna?? |
20-Aug-2022, 02:31 PM all the elrs receivers i have flashed no problem. Then I bought 8 betafpv 2.4 lite with flat antenna ?? any tips? 20-Aug-2022, 05:02 PM Return them? What error are you getting when you try to flash? Are you flashing via WiFi or Betaflight Passthrough? Are you flashing version 2.5.1 or newer? 20-Aug-2022, 11:44 PM 2.5 because that is on my module?....I tried wifi and betaflight pass-through 21-Aug-2022, 06:38 AM What is the error message you are getting? Try flashing ELRS 2.5.1, as all ELRS v2 versions are compatible. 21-Aug-2022, 11:14 PM I did not know that and will try that ....makes sense thank you |
Weird RXLOSS ELRS issue | Pathfinder075 | 5 | 63 | Today, 01:05 AM Last Post: Pathfinder075 | |
Help Super X V1 Bricked ELRS | Caelus_fpv | 11 | 359 | Yesterday, 03:37 PM Last Post: Caelus_fpv | |
ELRS 3.4.1 - massive problems after turning off model matching | Imp | 3 | 147 | 30-May-2024, 06:14 PM Last Post: SeismicCWave | |
TBS antenna | Cake | 0 | 73 | 30-May-2024, 10:20 AM Last Post: Cake | |
ELRS Module with Taranis X Lite | NYCDiesel | 14 | 390 | 17-May-2024, 10:56 PM Last Post: SeismicCWave |
