Do not flash Edge 2.8x for ELRS3
There is a ELRSv3 LUA out of memory error.
I had to flash back to Edge 2.7.1.
Supposedly once LUA is compiled you can go back to 2.8x, but I wasted enough 3am sleep.
Most important lesson I keep having to learn 50x -
once its working dont flash upgrade.
[-] The following 1 user Likes romangpro's post:
  • EyeBotXander
I've been using EdgeTX 2.8.0 on all my ELRS v3 radios without issue. What radio do you have?
No problem for me either. I'm running EdgeTX 2.8.1 with ExpressLRS 3.2.0 and the ELRS v3 LUA script. And that's on an old FrSky Taranis X9D+ SE transmitter.
Running the same as above on my Boxer, no issues at all.
I am terrible at flashing the latest firmware even it it ain't broke - having the latest stuff, trying it out and troubleshooting is half the 'fun' for me!
- Learning about and buying hardware
- Flashing firmware and configuring things
- Troubleshooting and setting it all up
- Sometimes I even do a bit of flying!
RM Boxer ELRS | Skyzone O30 | Mobula 6 ELRS | Mobula 7 ELRS | GepRC 3"
[-] The following 1 user Likes Diggery's post:
  • hawk01
Throwing in my worthless 2cents...
EdgeTX 2.8.0 (Fying Dutchman) On Jumper T V2 Elrs...
No issues...
Its an issue only on some radios.. my is Jumper TLite.
I have a jumper t12 pro and my module and Rx won’t read on beta flight. —
I went from crossfire over to ELRS and have yet to have it work. However the Rx I bought doesn’t flash so I think I have another issue and possibly also the radio issue.
I have now downloaded a new version of beta flight so maybe this will be my fix.
Anyone have a similar issue?
  ELRS flash fail - OSError: [Errno 25] Inappropriate ioctl for device drumgod 7 1,683 18-Jul-2023, 03:06 PM
Last Post: drumgod
  TX16S, Edge TX 2.7 - Crossfire agent lite issues clone2002 6 2,094 28-Nov-2022, 08:43 AM
Last Post: Dungfly21
  can not flash betafpv elrs lite v1.1 flat antenna?? Lennyp 4 662 21-Aug-2022, 11:14 PM
Last Post: Lennyp
  What does this tiny board do? Namimno Flash Oled Bundle Flying Dutchman 4 640 15-Mar-2022, 11:19 PM
Last Post: Flying Dutchman
  Solved Got my elrs tx and rx to flash and bind, but no signal in betaflight Sean Cleary 3 2,420 14-Feb-2022, 08:38 AM
Last Post: kafie1980
