21-Jun-2016, 08:19 PM
Soldered my LittleBee 20A ESC to the KISS FC.. but I am getting a lot of problem in making them work together.
1)Bad Motor desync issue
2)Had to disable Active Braking(The copter won't feel that locked in would it?)
3)Also change from Dampened Light to High in PWM on BLHELI(Had to do these changes in order to make the LB20A work with the KISS FC...previously they were used on XRacer FC)
Also I couldn't calibrate my escs as Oscar had mentioned on his blog. Had to do it using the suite by changing the ppm start and end points(1032-2000)
Can anyone tell me what is causing the problem?If possible can anyone post a snap of their BLHELI settings and KISS FC Configurator settings here...
