OSD issues......
Hi Folks....
I am trying to load the latest version of MW OSD on to my minimisd micro....with zero success. I have it plugged into my FTDI and I am not sure it's seeing the osd board. There is no activity on the osd (lights of any kind), but when I plug it I, two additional lights come on on the FTDI. All that said, the MS OSD software does not seem to recognize it. It just keeps flashing, "writing osd", but there is no indication it is actually doing any thing.....thoughts/comments?
so you flashed it okay? but can't read / configure it on the GUI?
can you try 1.4 quickly?
I am having the same issue on my micro minimOSD from banggood... only 1.4 works any newer version won't connect to the GUI, just says waiting for OSD...
(22-Mar-2016, 10:17 PM)Oscar Wrote: so you flashed it okay? but can't read / configure it on the GUI?
That's what mine says...I checked the pins on the FDIC board and I'm not getting any voltage...which would explain why none of the LEDS lit on the OSD.....which means I never got it flashed in the first place...OR it was flashed when I got it and it's just that version 1.5 is not working....I'll get 1.4 and try that.....Thanks Oscar.
I tried 1.4.1....now it says "waiting FC".........
might sound silly, you tried swapping TX/RX? and DTR is connected?
Doesn't sound silly.....DTR is connected and I will try swapping TX/RX, but I;ve got a sneaking suspicion I've got a bad FDIC board....I'll let you know what happens.
Swapped TX/RX...same thing. With no voltage at the 5v output of the FDIC board, I suspect there may be a problem with it.....
For anyone watching this thread.....I figured it out. I bought a Qunqi 3.3V 5.5V FT232RL FTDI Usb to TTL Serial Adapter and failed to read the "fine print", where it clearly says, "not supported in Windows 8". Crap.
  SpeedyBee F7 V3 Power Issues SoFarKingFast 8 752 13-Jun-2023, 09:54 PM
Last Post: Pennywise
  No OSD in DJI goggles after updating FC jeffames226 3 337 06-Sep-2022, 06:49 PM
Last Post: jeffames226
  230mm quad throttle issues. VarthDader 0 372 28-Mar-2022, 08:54 PM
Last Post: VarthDader
  Weird Throttle Chop Issues greenearwax 7 698 13-Oct-2021, 09:59 PM
Last Post: greenearwax
  No OSD Info HDO2 w RapdFire TheLostAlaskan 7 1,315 29-Aug-2020, 11:06 PM
