Need a little help with noisy video only when on throttle. Thanks!
I just recently built a DalRC XR215 using the included PDB, Eachine VTX, Foxeer Arrow v3, Emax rs2205, and Racerstar 20a esc. I used a Eachine camera for a few days and it didn't have lines but color was bleached out so I installed my Foxeer camera with a 4 pin cable instead of the 7 pin cause I am waiting for a new cable. The 4 pin cable has VCC, ground, audio, and video it just don't have the osd, osd ground , and voltage sensor wires. Anyway I also started using a pigtail on VTX instead of right angle. I did add signal ground wires to all esc and they didn't have any before on same esc's when on my Wizard. I know that this is alot to consider but just a idea where to start would be great! Arrrrggghhh I had zero issues for months now everytime I replace something I another issue comes up! Thanks for any help or advice!
What source are you using to power your camera?
Hey thanks for the reply! I just got it figured out yesterday! I just made the VTX and Camera share the VTX ground. No more lines!
[-] The following 2 users Like savannahmick's post:
  • RENOV8R, Tom BD Bad
  Seeking Programmable FPV video receiver for 1.2-1.3 GHz Frequency Range holysepac 0 137 13-Jan-2024, 06:56 PM
Last Post: holysepac
  i ripped off the video in pad of my jhemcu aio, looking for another vi source hugnosed_bat 6 365 07-Apr-2023, 12:10 AM
  Dark video feed HaveAPotato 4 382 29-Aug-2022, 09:11 PM
Last Post: HaveAPotato
  video not working, possibly ground or 5v too? GabeFPV 3 379 06-May-2022, 11:44 PM
Last Post: kafie1980
  RunCam Mini FPV DVR Video Audio Recorder 25 x 25mm JeBear76 5 914 14-Oct-2021, 08:57 PM
Last Post: JeBear76
