My fly sky i6 is bound but won't control my drone
(30-Jan-2017, 04:14 PM)Ikkuh Wrote: Can you maybe add some pictures from your setup, like receiver connection, FC connection etc.
The RX should be connected this way:
[Image: rx-2-ff998967.jpg]
I will when I get off work it will be later on this evning, my RX is connected as you have shown in the picture and the light is solid when my i6 is turned on
My RX is connected just like that, and the red light turns solid red when I turn my i6 on but no conection to the board?? All I did was reset my TX
I think the wizard comes with an ia6 receiver with does not support PPM or IBUS. Have you tried PWM.
#19
(13-Jul-2017, 11:10 PM)voodoo614 Wrote: I think the wizard comes with an ia6 receiver with does not support PPM or IBUS. Have you tried PWM.
Sorry for the delayed response but with the help of some people i realized what you just said. I ordered the x6b and it i'm just waiting for it to come in now and hopefully I get to fly finally.
#20
(14-Jul-2017, 10:32 PM)Something1317 Wrote: Sorry for the delayed response but with the help of some people i realized what you just said. I ordered the x6b and it i'm just waiting for it to come in now and hopefully I get to fly finally.
Hi, I have had the exact same issue, i can't get the fs-i6 to connect to Cleanflight. I am using the fs-ia6b receiver. the flight controller connects fine. I am using the F3 Flight Controller Acro 6 DOF/Deluxe.
I have gone back over every tutorial and made sure ppm mode is on, on the fs-i6.
[Image: 2fOqE4Il.png]
[Image: NyKQkZvl.png]
#21
(08-Nov-2017, 12:07 AM)hoodedhorntail Wrote: Hi, I have had the exact same issue, i can't get the fs-i6 to connect to Cleanflight. I am using the fs-ia6b receiver. the flight controller connects fine. I am using the F3 Flight Controller Acro 6 DOF/Deluxe.
Looks like you have it set doe PPM. How is your RX wired to your FC?
#22
Have you tried changing the AFHDS mode?
In the TX menu, go into system ->RX Setup -> RF standard and try swapping the AFHDS / AFHDS 2A setting?
can you give us a screen shot of the ports tab?
#23
(08-Nov-2017, 01:41 AM)voodoo614 Wrote: Looks like you have it set doe PPM. How is your RX wired to your FC?
Hi thanks for the reply, here is how it's wired up. It's the red black and white wire on the right hand side. I am following along to this video.
about 14 mins in.
Also I tried changing the AFHDS mode to off but the fs-i6 would not connect to the fs-ia6b after that so I changed it back
[Image: rtQdc7tl.jpg]
[Image: NJBiDA7l.jpg]
(08-Nov-2017, 05:27 AM)Tom BD Bad Wrote: Have you tried changing the AFHDS mode?
Hi thanks for the reply, here is a picture of the ports tab.
[Image: oWSAEaUl.png]
#24
2 remarks:
1. it seems you have rx connected to UART 3 yet in config you selcted uart 2 for RX ?
2. have you selected ibus/sbus on the config page for the rx setup?
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
#25
Thanks for getting back Grisha0, I have changed it to use UART3 now instead of UART2.
I am not sure what you mean by selected ibus/sbus on the rx setup. If I select i-BUS setup on the fs-i6 it just shows different channels e.g. CH1.
#26
nah,
rx setup is 2 step (or multi but here i'd like to focus on two) - and im focusing only on the quad side, i assume the TX is configured and bound.
1. tell the system where it should expect rx signal from - this is the step you do now on the screen attached by you (ports tab)
2. go to config tab, if i remember correctly next step is on config page you'd need to scroll down (like mid of scroll) and on the lefthanside there will be rx options is it ibus/sbus/ppm/pwm etc, try to select ibus at first and save.
go to rx tab and see if it works
All the best
[-] The following 1 user Likes Grisha0's post:
  • WierdBeardFPV
#27
(09-Nov-2017, 10:54 PM)Grisha0 Wrote: nah,
Hi brill I think I have found where you mean. I have made the following change and it is now moving the Roll, pitch and throttle inside of clean flight. this is a big step forward, thanks.
[Image: NE7L2DFl.png]
The last step is to get the controller to actual power the motors. I have got the motors working by controlling them on clean flight. Is there anything else I need to do to get the fs-i6 to power my quad?
#28
good place, good config ... now
1. ENSURE YOU HAVE PROPS OFF.
2. look at point 1.
3. sure that point 1 completed?
4. on the receiver tab you will see modes (dropdown with options) once you will select AFAIR AERT smth... hit save your sticks should be good.
5. but first check point 1.
if you see all "sticks" are moving the correct bars - ie throttle moves throttle not roll...
then you will also need to setup the "Modes tab" set one of the switch that you tested on the receiver tab to "ARM" in the middle
hit save.
look at point 1 again...
flip the switch...
All the best
  • hoodedhorntail
#29
(09-Nov-2017, 11:04 PM)Grisha0 Wrote: good place, good config ... now
2. look at point 1.
hit save.
flip the switch...
Thanks again, so the props are definitely off, I checked point 1 a few times :-) the throttle is moving the throttle, so i went into modes and set the following. I am a bit of a noob so I think I have set it wrong. Please see attached.
[Image: Z9rOiMTl.png]
If nothing else this thread will hopefully help anyone else with this issue.
So grateful for your time on this.
#30
(09-Nov-2017, 11:15 PM)hoodedhorntail Wrote: Thanks again, so the props are definitely off, I checked point 1 a few times :-) the throttle is moving the throttle, so i went into modes and set the following. I am a bit of a noob so I think I have set it wrong. Please see attached.
IT WORKS!!!!! thanks so much!!!! I changed the modes to the following and rebooted the flight controller and it worked.... My son is going to be so chuffed. We have been working on this together. thanks again you have been a great help!!!
[Image: 1bzGOnMl.png]
[-] The following 3 users Like hoodedhorntail's post:
  • Leej8, Tom BD Bad, Grisha0
  Poor range and sudden loss of control with TBS CRSF husafreak 23 1,415 01-Apr-2024, 07:52 AM
Last Post: Cake
  Help Tango 2 does not connect to the (TBS CRSF nano RX)drone receiver but updates it Maksym 1 170 25-Feb-2024, 12:34 AM
Last Post: Cake
  [SOLVED] Radio wont pair when drone is powered via battery mulapickle 5 299 16-Jan-2024, 03:26 PM
Last Post: mulapickle
  Elrs receiver bound but Betaflight not working olikity 8 2,186 15-Aug-2023, 10:38 PM
Last Post: kbah
  Help R-XSR bound to TX16S but not recieving input or talking to betaflight jswillis 3 453 27-Jul-2023, 07:52 AM
