Threads: 1
Likes Received: 0 in 0 posts
0 I bought a pre-armed fpv drone, and configured it in betaflight, everything was perfect. days after a perfect operation I decided to update the firmware of my flight controller a luminer lux mini f7 and the problem started.
When trying to take off the drone it turns around and I don't understand what the problem is since I have made the configurations as it was from the factory and I have tried many configurations but none have worked for me
any solution?
Threads: 75
Likes Given: 3,949
121 04-Oct-2022, 07:39 AM (This post was last modified: 04-Oct-2022, 07:41 AM by Lemonyleprosy.) When you say it turns around when you try to take off, it makes me think you might be in turtle mode.
Beyond that, the easiest way to get things functional as it was is to go back to the original firmware version and load the manufacturer’s original settings.
What drone do you have?
Dangerous operations.
Threads: 583
Likes Received: 8,954 in 6,625 posts
Likes Given: 1,425
786 I'm guessing that you didn't run a "diff all" in the CLI and saved the output to a file before you flashed new firmware. A golden rule of thumb is to run a "dump all" and a "diff all" as soon as you take delivery of a new quad so you have a copy of the original factory settings, and always run a "diff all" prior to making any new configuration changes so if you manage to mess something up you can then just restore the settings you saved before you made any changes.
Was there a specific reason for you updating the firmware version? Unless you have a very good reason to do so the then it is usually advisable to just leave a BNF quad with the firmware version it came shipped with.
It sounds like you probably have the FC or gyro orientation settings incorrectly configured.
I would contact GetFPV and ask them if they can provide you with a copy of the original factory CLI dump. If they do then make sure you flash the quad back on the same version of Betaflight that the CLI dump is for before applying it (the version number is shown in the header of the CLI dump). Can you please also post the CLI dump back here as it will help others in the future who are searching for the same.
