I was having issues with my flight controller beta flight wasn’t recognizing the flight controller so I rebooted downloaded the latest firmware. After doing that beta flight recognize it. But flight controller not recognizing receiver now so tried doing an older version of their firmware still know response. Receiver is bond to the remote so I tried a different drone same issue not sure something isn’t turned on or off. I’m pretty new to beta flight trying to navigate around it. Went to the cli. If anyone can help me out I would appreciate it ! The flight controller is iflight succex -e- f722
I’ve never built my own drone before so I’ve never messed around in the cli tap. If anyone can give me a hand I would appreciate it.
adjrange - configure adjustment ranges
<index> <unused> <range channel> <start> <end> <function> <select channel> [<center> <scale>]
aux - configure modes
<index> <mode> <aux> <start> <end> <logic>
batch - start or end a batch of commands
start | end
beacon - enable/disable Dshot beacon for a condition
list
<->[name]
beeper - enable/disable beeper for a condition
list
<->[name]
bind_rx - initiate binding for RX SPI or SRXL2
bl - reboot into bootloader
[rom]
board_name - get / set the name of the board model
[board name]
color - configure colors
defaults - reset to defaults and reboot
{show} {nosave} {bare} {group_id <id>}
diff - list configuration changes from default
[master|profile|rates|hardware|all] {defaults|bare}
dma - show/set DMA assignments
<> | <device> <index> list | <device> <index> [<option>|none] | list | show
dshot_telemetry_info - display dshot telemetry info and stats
dshotprog - program DShot ESC(s)
<index> <command>+
dump - dump configuration
exit
feature - configure features
list
<->[name]
flash_erase - erase flash chip
flash_info - show flash chip info
flash_read
<length> <address>
flash_scan - scan flash device for errors
flash_write
<address> <message>
get - get variable value
[name]
gpspassthrough - passthrough gps to serial
gyroregisters - dump gyro config registers contents
help - display command help
[search string]
led - configure leds
manufacturer_id - get / set the id of the board manufacturer
[manufacturer id]
map - configure rc channel order
[<map>]
mcu_id - id of the microcontroller
mixer - configure mixer
list
<name>
mmix - custom motor mixer
mode_color - configure mode and special colors
motor - get/set motor
<index> [<value>]
msc - switch into msc mode
[<timezone offset minutes>]
play_sound
[<index>]
profile - change profile
[<index>]
rateprofile - change rate profile
[<index>]
rc_smoothing_info - show rc_smoothing operational settings
resource - show/set resources
<> | <resource name> <index> [<pin>|none] | show [all]
rxfail - show/set rx failsafe settings
rxrange - configure rx channel ranges
save - save and reboot
sd_info - sdcard info
serial - configure serial ports
serialpassthrough - passthrough serial data data from port 1 to VCP / port 2
<id1> [<baud1>] [<mode1>] [none|<dtr pinio>|reset] [<id2>] [<baud2>] [<mode2>]
servo - configure servos
set - change setting
[<name>=<value>]
signature - get / set the board type signature
[signature]
simplified_tuning - applies or disables simplified tuning
apply | disable
smix - servo mixer
<rule> <servo> <source> <rate> <speed> <min> <max> <box>
reset
load <mixer>
reverse <servo> <source> r|n
status - show status
tasks - show task stats
timer - show/set timers
<> | <pin> list | <pin> [af<alternate function>|none|<option(deprecated)>] | list | show
version - show version
vtx - vtx channels on switch
<index> <aux_channel> <vtx_band> <vtx_channel> <vtx_power> <start_range> <end_range>
vtx_info - vtx power config dump
vtxtable - vtx frequency table
<band> <bandname> <bandletter> [FACTORY|CUSTOM] <freq> ... <freq>
# sucees
###ERROR IN input: UNKNOWN COMMAND, TRY 'HELP'###
# help
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
# succex e f722
# succex
# help
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
succex e f722
# succex
# help
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
# sucees
# help
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
# succex e f722
# succex
# help
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
name>
<index> [<value>]
play_sound
[<index>]
[<index>]
[<index>]
[<name>=<value>]
[signature]
apply | disable
smix - servo mixer
reset
load <mixer>
succex e f722
# succex
# help
start | end
list
<->[name]
list
<->[name]
[rom]
[board name]
<index> <command>+
exit
list
<->[name]
flash_read
<length> <address>
flash_write
<address> <message>
[name]
[search string]
[manufacturer id]
[<map>]
list
<name>
