22-Feb-2024, 07:09 PM
Hi all,
At this point I’m calling out for help, I’m stuck, and it’s been more than a week
I’m trying to leverage the ESP8285 chip (with Wifi capabilities) from the MATEK F 405 WTE.
When I plug the FC to USB (via the USB Extender), my laptop opens the serial connection (under "/dev/tty.usbmodem0x000001"). From there I can use the INav Configurator no problem.
To get access to the embedded ESP8285, I followed the steps described here (mateksys website):
Wiring ETx (FC) to D- (USB Extender), ERx (FC) to D+ (USB Extender), as well as 4v5 and G (FC) to 4v5 and G (USB Extender).
I’ve been trying different configs for the cables, but despite all my efforts, the laptop does not “see” the serial connection (nothing new under /dev/tty*)
I’ve been trying to reproduce the behavior using a Raspberry Pi 4, and I get the same behavior (when plugged in directly, the FC is recognized, but nothing when I try to reach the ESP8285 using the wiring described on the Matek website)
It is worth mentioning that the ESP8285 chip itself is not “dead” since it runs the ELRS Receiver by default. I can connect to it via Wifi. Its dedicated LED is blinking on the FC:
Other things I’ve tried:
- Switching ERx and ETx cable to USB Extender “D-“ or “D+” (just in case), no result
- Using different FC pins to get 4v5 and ground.
Config :
- FC : Matek F405 WTE
- Laptop : Mac Sonoma 14.2.1
- Firmware on the FC: 7.0.0
- INav configurator (on mac): 7.0.1
- No other equipment is connected to the FC (no GPS, no servos, no ESC, no SD Card…)
- My soldering seems ok
Any help or direction for next steps would be greatly appreciated (even a confirmation that what I’m trying to do should work ok)!
Thanks a lot!
Rémi
Config :
Thanks a lot!
Rémi
