Threads: 92
Likes Given: 0
27 22-Aug-2021, 05:06 PM (This post was last modified: 22-Aug-2021, 05:07 PM by romangpro.) 3" quad. Hifion F7 AIO 45A. Apex1303.6. I've flown it maybe 30+ times.
I was flying around parking lot at night. Some propwash.
Plugged into phone Speedybee and changed PID.. upped the D.. changed vtx channel. Save.
Wont arm. Reports "rpmfilter". Then I realize, there is no ESC chime.
The LED lights turn on, because it recognizes the radio.
Come back home. Plug in. Betaflight shows nothing weird. 4K. DShot300. Bidir enabled.
Connect to BLHeli_Configuration. Read Setup. Nothing shows up.
There are NO ESC.
Yes, it is BLHeli_S and yes I am using right program.
Threads: 172
Likes Received: 2,286 in 1,833 posts
Likes Given: 4,736
100 probably its a bug, no signal or passtrough. i would try to flash the firmware fresh
Threads: 92
Likes Given: 0
27 I full erase flashed. No difference.
How can all 4 ESC be missing?
I guess its time to disassemble, and use multimeter. Very likely microcontrollers are getting shorted.
Threads: 16
Likes Received: 176 in 149 posts
Likes Given: 26
8 22-Aug-2021, 11:48 PM (This post was last modified: 22-Aug-2021, 11:49 PM by MrSolo.) So strange that NO esc's appear!
Since the warning flag is RPMFILTER have you tried turning OFF bi-directional dshot in betaflight? If it was on, that is. (I don't know why that would make any difference as you were just flying, but since it's just one click I would try it out)
I don't understand why it would suddenly not work after flying and only changing PID and channel.
Threads: 92
Likes Given: 0
27 Also.. the BLHeli_S logs are not usefull.
Reading setup
sending cmd_DeviceInitFlash 0 0
received cmd_DeviceInitFlash ACK_D_GENERAL_ERROR 0 0,0,0,0
ESC 1 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
sending cmd_DeviceInitFlash 0 1
ESC 2 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
sending cmd_DeviceInitFlash 0 2
ESC 3 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
sending cmd_DeviceInitFlash 0 3
ESC 4 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
Threads: 92
Likes Given: 0
27 Anybody know where to buy
8K910
its very likely the 3.3V LDO thats dead because LED work and Im getting 4.9V on 5V pads
Threads: 120
Likes Received: 1,422 in 738 posts
Likes Given: 1,100
42 Awesome work roman! Thankyou for sharing your diagnosis process. Very informative.
