20-Feb-2024, 02:29 AM
"Just an FYI incase someone else has a similar issue...."
I finally got around to connecting my HGLRC M100-5883 ("NON-Mini") GPS , And upon double, triple checking all the wires etc, Hooking up a battery etc, Everything lite up EXCEPT the GPS...
So....... I pulled everything apart and did a continuity check from the GPS 6 wire plug on the FC side, To the plug that connects to the GPS module itself..
And all Pins checked out - 1 for 1 - And had continuity on all 6 from the FC side to the actual pads on the top side of the GPS itself..
One thing I found very weird, Was the Power and ground coming outta FC had the Power on Pin 5 and the ground on Pin 6. (could be pins 1&2 b ut im too lazy to look right now, but you get my drift) But on the GPS side the Ground was on Pin 1 and the power was on pin2 .
So I just reversed the 2 wires on the FC side, and she powered right up...
Weird, I dont think I grabbed a different harness plug, Only bc Ive never had any 6 wire plugs before this install. Maybe I was given a harness and the 2 wires were reversed??? I Dunno...
Which goes to show everyone, When Applicable!!!! Always solder when you have the ability too...
I will leave the clip plugged into the GPS itself, as I have it hot glued into the unit itself. But I WILL ABSOLUTLEY SOLDER the GPS wires directly onto the FC pads as soon as the wife goes to bed, and leaves me alone, so I can go into my garage and goto town....
-Thanks Again Guys
-Thanks Again Guys
