fpv goggle problem
hi all,
I have a problem that I din't solve it. I need help. The problem is my emax trasporter 2 fpv goggle has dark screen center of the screen. I have two drones mobula8 and darwinfpv cineape25 both have the same issue. I attach the link below to describe the problem well. I didn't figure out the problem caused by vtx or the camera I hope a person who has experience helps me.
https://photos.app.goo.gl/42bj7XsKaW9TUXat6
That's a really bad picture.
It looks to be wrapped in a plastic bag, why??
Is that across the back too, stopping the cooling fan working?
The dark patch just looks like where the bag is touching the screen??
I will submit again new picture I agree. The picture is meaningless.
Better!
Point the camera at a plain evenly lit wall and lets see what you get?
[-] The following 1 user Likes Bad Raven's post:
  • kursad
Any chance the screen in the goggles was left exposed to sunlight? Or the goggles left on for an inordinate amount of time?
Screen burn is usually far more distinct edged
(24-Jun-2023, 12:12 PM)Bad Raven Wrote: Better!
When i point the camera on the wall issue is continues.
(24-Jun-2023, 12:38 PM)FPVme Wrote: Any chance the screen in the goggles was left exposed to sunlight?  Or the goggles left on for an inordinate amount of time?
I didn't use the goggle much. I wonder I could have other goggles, Do I have same issue. I think this is goggle problem.
If you viewed the video from two different drones and the dark square is in exactly the same spot all the time, then the problem is likely with your goggles. If the image detail looks clear just the brightness is too dark, then maybe the backlight on the LCD screen is damaged or defective. If your goggles has a brightness setting, you can try adjusting it to see if it makes any changes - but probably you need to replace the screen.
(24-Jun-2023, 02:11 PM)mstc Wrote: If you viewed the video from two different drones and the dark square is in exactly the same spot all the time, then the problem is likely with your goggles. If the image detail looks clear just the brightness is too dark, then maybe the backlight on the LCD screen is damaged or defective. If your goggles has a brightness setting, you can try adjusting it to see if it makes any changes - but probably you need to replace the screen.
sir I tried your advice that I increase the backlight and same problem is continue.
I bought new goggle. Problem had been goggle. Everything is okay now.
[-] The following 1 user Likes kursad's post:
  • FPVme
Enjoy flying!
  Discussion Goggle choices in 2024? husafreak 74 3,336 14-Apr-2024, 11:46 PM
  Problem with Foxeer reaper extreme oklidog 8 1,441 12-Apr-2024, 09:33 PM
Last Post: PrOpJuNkiE
  New Product SpeedyBee 5.8GHz FPV Goggles Receiver Module (Analog) SnowLeopardFPV 2 1,370 14-Feb-2024, 03:24 PM
  Help FPV goggles antenna boooood 2 729 04-Dec-2023, 05:38 AM
Last Post: Rob3ddd
  Discussion Option to receive analog and digital signals in DJI Goggle with external module percy3 5 8,895 27-Sep-2023, 12:55 PM
