Foxeer f303 can't connect to CF,BaseF,RF,BF ?
I tried all kind of configurators but It didnt.
I have Foxeer F303 fc. and I did short boot pins, and upload that Which firmare preferred. It is all ok.. but When I reconnect Cleanflight, BF,RC... It doesnt connect, I changed computer and usb cable too. but still going on  this problem.
I see that The FC has led light, nowhere any other light on it.
[Image: nEO220.jpg]
What firmware?
I tried, BF 2.9.1 - BF 3.0 and tried standart Naze firmware too.
Ok, are you sure that it gets flashed properly? You choose the correct FC in the drag down menu in Betaflight GUI?
I have problems using my windows computer when flashing in bootloader mode (I guess it is some driver problems, but since I also got a mac, I normally use that one when I get problems when flashing). I'm sorry if it is not very helpful for you, but I guess there are someone here with the same driver problem that can step in if it is a driver issue
Look at this, I have other fc here Naze32 rev 5, and It properly works kindly. Smile and I see "succes" after flashing Foxeer F303.  any other thing, Big Grin
[Image: nEO2l5.jpg]
[Image: vZjRPm.jpg]
[Image: 1NJrEY.jpg]
Which board could I choose from BF for my Foxeer f303?
[Image: Y4gJ76.jpg]
I solve this problem with true card choosing.... Thanks for helps
and I think this information is very important for Who doesnt know FC ?
"SOFTWARE:
The F303 flight controller runs on the open source Clean flight software and its compatible with the Boris B. Beta flight firmware. The hex file to use is spracingf3 hex. "
If you scroll down a bit on the "Choose a board" window, you should see the spracing target. Is that the FW you have tried to flash? from your last picture it looks like you choose the doge fc
Yes I have written upside, Thanks again...
That is strange. You are doing things in this order?
1. short the boot pins and plug in the USB cable, there should only be light in the blue led
2. Choose the SPRacing board
3. Choose "no reboot sequence", "full chip erase" and "manual baud = 256000"
4. Flash the firmware
5. when flashing is succesful, The Betaflight GUI will tell you so and you can disconnect the board
5. Disconnect the boot pin
6. connect the board to the usb, hit connect and it should work
Here is a review I found about the board:
https://rfengfpv.wordpress.com/2016/07/1...ng-review/
[-] The following 1 user Likes oyvinla's post:
  • BigglesFPV
Not sure, but I think he solved the problem - that's how I read his edit (and his note afterwards) anyway....
(13-Sep-2016, 01:16 PM)oyvinla Wrote: That is strange. You are doing things in this order?
order style just this ,
1. short the boot pins and plug in the USB cable, there should only be light in the red led (the blue light that you have seen, ıt is older fc)
I am having the same problem with my foxeer f3 board. I can't get it to connect or flash it using betaflight or cleanflight. Any help would be great.
  Help Foxeer Reaper AIO V4 F745 45A BadRaven 15 1,553 04-Jan-2024, 07:17 AM
Last Post: BadRaven
  FPV remote won't connect to computer or DJI assistant software nicolomaserati 10 4,139 19-Mar-2023, 02:19 PM
  Help: changed PID loop frequentie and cannot connect to Betaflight anymore JPDK 5 504 04-Mar-2023, 04:00 PM
  Solved HGLRC F722 fail to connect after successful flash Bud13420 3 455 30-Nov-2022, 07:05 PM
Last Post: Bud13420
  News PSA: Do not power up or connect via USB Whoop AIO boards before reading this kafie1980 13 1,794 15-Jul-2022, 08:26 AM
