Getting error "found multiple esc configuration blhelisuite32" , re-flashing of ESC fails ? I am able to spin each motor individually in BF, I use BF 4.4.2 if it matters
found multiple esc configuration blhelisuite32 |
First question.. does your esc have blehli32 ? I have tried to use BLHELI 32 comfig / suite while having blheliS in my esc.. 23-Jul-2023, 08:28 PM Getting this when using blheliS Reading setup sending cmd_DeviceInitFlash 0 0 received cmd_DeviceInitFlash ACK_OK 0 6,54,108,4 sending cmd_DeviceReadEEprom 0 112 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 ESC 1 read settings failed cmd_DeviceReadEEprom ACK_I_INVALID_CMD sending cmd_DeviceInitFlash 0 1 received cmd_DeviceInitFlash ACK_OK 0 6,54,108,4 sending cmd_DeviceReadEEprom 0 112 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 ESC 2 read settings failed cmd_DeviceReadEEprom ACK_I_INVALID_CMD sending cmd_DeviceInitFlash 0 2 received cmd_DeviceInitFlash ACK_OK 0 6,54,108,4 sending cmd_DeviceReadEEprom 0 112 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 ESC 3 read settings failed cmd_DeviceReadEEprom ACK_I_INVALID_CMD sending cmd_DeviceInitFlash 0 3 received cmd_DeviceInitFlash ACK_OK 0 6,54,108,4 sending cmd_DeviceReadEEprom 0 112 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 received cmd_DeviceReadEEprom ACK_I_INVALID_CMD 0 0 ESC 4 read settings failed cmd_DeviceReadEEprom ACK_I_INVALID_CMD Reading setup <span style="color: green">finished</span> Please use the lateat version of BL_32Suite, it is currently: 32.9.0.5. This may help. Order of connection. 1) props off! 2) make sure TX is off. 3) put a usb fan on stack/vtx to stop overheating 4) plug in lipo battery 5) close BF configurator 6) run bl-32suite and try scanning all escs again. 24-Jul-2023, 01:44 PM (24-Jul-2023, 05:45 AM)ph2t Wrote: Please use the lateat version of BL_32Suite, it is currently: 32.9.0.5. This may help. That did it ! Thnx a lot , appreciate 25-Jul-2023, 01:46 AM You're welcome mate, happy to help! |
Is it possible to test if an ESC works without soldering? | HypnoToad | 2 | 143 | 23-Mar-2024, 07:22 PM Last Post: HypnoToad | |
BLHeliSuite32 32.10.0.0 HELP | Coleon | 37 | 1,053 | 02-Mar-2024, 03:25 PM Last Post: mstc | |
Noob Question..... "VTX/ESC" Boards.... | Coleon | 12 | 351 | 02-Mar-2024, 12:35 PM Last Post: Luk5569 | |
SpeedyBee F7 ESC Question... | Coleon | 6 | 415 | 30-Jan-2024, 07:05 AM Last Post: Coleon | |
SpeedyBee F7/ESC Cap Question.. | Coleon | 5 | 349 | 27-Jan-2024, 10:07 PM Last Post: Coleon |
