Flight Problems with Tiny Whoop variant
I have a Tiny Whoop that will rarely fly more than 10 inches above the ground.  It powers on, arms and lifts off for maybe 20 seconds to 30 inches then continuously hovers about 10 inches above the ground for several minutes.
I've checked the CW/CCW setting and props.
I've tried replacing the motors, blades and modded it to use the larger connectors for the battery.
It has a Bee Brain v.1 micro brushed FC, BetaFPV 3 blade props, AKK A1 Mini FPV transmitter.
I have two battery tails on it, one for original Micro JST and one for 2.0 JST.
I'm using the NitroNectar 250mAh 3.8v batteries with 2.0 JST right now.
Total weight with battery is 30 grams.
My controller is a Taranis X9D+.
See attachments with pictures
I'm assuming it is power-related but don't know where to start researching.
Thanks!
Attached Files Thumbnail(s)
What has me thinking that it's NOT a power-related problem is the fact that you say it hovers for several minutes. Sounds more like a throttle endpoint settings issue. But I could be wrong..............
(01-Dec-2017, 09:12 PM)RENOV8R Wrote: What has me thinking that it's NOT a power-related problem is the fact that you say it hovers for several minutes.  Sounds more like a throttle endpoint settings issue.  But I could be wrong..............
Thanks.  I'll review the betaflight settings and see if I find something!
  Build Flylens85 Walksnail 3S cruise whoop build mstc 8 271 04-Apr-2024, 05:14 AM
Last Post: Cyberess
  LHCP ufl Antenna suggestion for 80mm whoop Maverick 19 818 12-Mar-2024, 11:41 AM
Last Post: Yohfpv
  Pavo Pico Brushless Whoop Quadcopter HD version Giedrius121 4 244 23-Feb-2024, 02:51 AM
  75mm whoop - budget conscious build Pathfinder075 25 1,050 13-Feb-2024, 05:48 AM
  sluggish whoop, possible causes? WoodenShoeNo 5 181 02-Feb-2024, 01:27 AM
