So, I have an F7 55A AIO Board Flight Controller and I installed crossfire, but when I go to Betaflight and change the receiver from SBUS to CRSF the stick bars disappear. Does anyone know what it could be?
(14-Jan-2024, 06:07 PM)SnowLeopardFPV Wrote: Can you please run the "dump", "diff all", and "status" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
Please also post some good clear photos of the actual wiring and connections between your receiver and the flight controller.
# led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0
# master set gyro_hardware_lpf = NORMAL set gyro_lpf1_type = PT1 set gyro_lpf1_static_hz = 150 set gyro_lpf2_type = PT1 set gyro_lpf2_static_hz = 300 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = AUTO set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_count = 2 set dyn_notch_q = 300 set dyn_notch_min_hz = 100 set dyn_notch_max_hz = 550 set gyro_lpf1_dyn_min_hz = 150 set gyro_lpf1_dyn_max_hz = 300 set gyro_lpf1_dyn_expo = 5 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = 29,-29,-12,1 set baro_bustype = I2C set baro_spi_device = 0 set baro_i2c_device = 1 set baro_i2c_address = 0 set baro_hardware = AUTO set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rssi_src_frame_lpf_period = 30 set rssi_smoothing = 125 set rc_smoothing = ON set rc_smoothing_auto_factor = 250 set rc_smoothing_auto_factor_throttle = 250 set rc_smoothing_setpoint_cutoff = 12 set rc_smoothing_feedforward_cutoff = 12 set rc_smoothing_throttle_cutoff = 20 set rc_smoothing_debug_axis = ROLL set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = SBUS set serialrx_inverted = OFF set sbus_baud_fast = ON set airmode_start_throttle_percent = 25 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set msp_override_channels_mask = 0 set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set blackbox_sample_rate = 1/4 set blackbox_device = SPIFLASH set blackbox_disable_pids = OFF set blackbox_disable_rc = OFF set blackbox_disable_setpoint = OFF set blackbox_disable_bat = OFF set blackbox_disable_alt = OFF set blackbox_disable_rssi = OFF set blackbox_disable_gyro = OFF set blackbox_disable_acc = OFF set blackbox_disable_debug = OFF set blackbox_disable_motors = OFF set blackbox_mode = NORMAL set blackbox_high_resolution = OFF set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 550 set dshot_burst = OFF set dshot_bidir = ON set dshot_edt = OFF set dshot_bitbang = AUTO set dshot_bitbang_timer = AUTO set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set motor_output_reordering = 0,1,2,3,4,5,6,7 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 15 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set failsafe_recovery_delay = 10 set failsafe_stick_threshold = 30 set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 45 set bat_capacity = 0 set vbat_max_cell_voltage = 430 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 330 set vbat_warning_cell_voltage = 350 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_display_lpf_period = 30 set vbat_sag_lpf_period = 2 set ibat_lpf_period = 10 set vbat_duration_for_warning = 0 set vbat_duration_for_critical = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 100 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = ON set mixer_type = LEGACY set crashflip_motor_percent = 0 set crashflip_expo = 35 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 180 set imu_process_denom = 2 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set deadband = 5 set yaw_deadband = 5 set yaw_control_reversed = OFF set pid_process_denom = 1 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set simplified_gyro_filter = ON set simplified_gyro_filter_multiplier = 60 set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set ledstrip_brightness = 100 set osd_units = METRIC set osd_warn_bitmask = 8191 set osd_rssi_alarm = 20 set osd_link_quality_alarm = 80 set osd_rsnr_alarm = 4 set osd_cap_alarm = 1100 set osd_alt_alarm = 100 set osd_distance_alarm = 0 set osd_esc_temp_alarm = 0 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_logo_on_arming = OFF set osd_logo_on_arming_duration = 5 set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2304 set osd_rssi_pos = 162 set osd_link_quality_pos = 224 set osd_link_tx_power_pos = 341 set osd_rsnr_pos = 341 set osd_tim_1_pos = 341 set osd_tim_2_pos = 2464 set osd_remaining_time_estimate_pos = 341 set osd_flymode_pos = 14560 set osd_anti_gravity_pos = 341 set osd_g_force_pos = 341 set osd_throttle_pos = 341 set osd_vtx_channel_pos = 20 set osd_crosshairs_pos = 312 set osd_ah_sbar_pos = 313 set osd_ah_pos = 185 set osd_current_pos = 551 set osd_mah_drawn_pos = 583 set osd_wh_drawn_pos = 341 set osd_motor_diag_pos = 341 set osd_craft_name_pos = 14656 set osd_pilot_name_pos = 14368 set osd_gps_speed_pos = 341 set osd_gps_lon_pos = 341 set osd_gps_lat_pos = 341 set osd_gps_sats_pos = 341 set osd_home_dir_pos = 341 set osd_home_dist_pos = 341 set osd_flight_dist_pos = 341 set osd_compass_bar_pos = 341 set osd_altitude_pos = 341 set osd_pid_roll_pos = 341 set osd_pid_pitch_pos = 341 set osd_pid_yaw_pos = 341 set osd_debug_pos = 341 set osd_power_pos = 519 set osd_pidrate_profile_pos = 341 set osd_warnings_pos = 14392 set osd_avg_cell_voltage_pos = 2336 set osd_pit_ang_pos = 341 set osd_rol_ang_pos = 341 set osd_battery_usage_pos = 2072 set osd_disarmed_pos = 2251 set osd_nheading_pos = 341 set osd_up_down_reference_pos = 312 set osd_ready_mode_pos = 341 set osd_esc_tmp_pos = 111 set osd_esc_rpm_pos = 11 set osd_esc_rpm_freq_pos = 341 set osd_rtc_date_time_pos = 341 set osd_adjustment_range_pos = 341 set osd_flip_arrow_pos = 341 set osd_core_temp_pos = 341 set osd_log_status_pos = 341 set osd_stick_overlay_left_pos = 341 set osd_stick_overlay_right_pos = 341 set osd_stick_overlay_radio_mode = 2 set osd_rate_profile_name_pos = 341 set osd_pid_profile_name_pos = 341 set osd_profile_name_pos = 341 set osd_rcchannels_pos = 341 set osd_camera_frame_pos = 142 set osd_efficiency_pos = 341 set osd_total_flights_pos = 341 set osd_aux_pos = 341 set osd_sys_goggle_voltage_pos = 341 set osd_sys_vtx_voltage_pos = 341 set osd_sys_bitrate_pos = 341 set osd_sys_delay_pos = 341 set osd_sys_distance_pos = 341 set osd_sys_lq_pos = 341 set osd_sys_goggle_dvr_pos = 341 set osd_sys_vtx_dvr_pos = 341 set osd_sys_warnings_pos = 341 set osd_sys_vtx_temp_pos = 341 set osd_sys_fan_speed_pos = 341 set osd_stat_bitmask = 14124 set osd_profile = 1 set osd_profile_1_name = - set osd_profile_2_name = - set osd_profile_3_name = - set osd_gps_sats_show_hdop = OFF set osd_displayport_device = MSP set osd_rcchannels = -1,-1,-1,-1 set osd_camera_frame_width = 24 set osd_camera_frame_height = 11 set osd_stat_avg_cell_value = OFF set osd_framerate_hz = 12 set osd_menu_background = TRANSPARENT set osd_aux_channel = 1 set osd_aux_scale = 200 set osd_aux_symbol = 65 set osd_canvas_width = 53 set osd_canvas_height = 20 set osd_craftname_msgs = OFF set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set enable_stick_arming = OFF set vcd_video_system = HD set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_msp_fonts = 0,0,0,0 set displayport_msp_use_device_blink = OFF set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set led_inversion = 0 set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set usb_msc_pin_pullup = ON set flash_spi_bus = 3 set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0 set rcdevice_feature = 0 set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW180 set gyro_1_align_roll = 0 set gyro_1_align_pitch = 0 set gyro_1_align_yaw = 1800 set gyro_2_bustype = SPI set gyro_2_spibus = 2 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = CW180 set gyro_2_align_roll = 0 set gyro_2_align_pitch = 0 set gyro_2_align_yaw = 1800 set i2c1_pullup = OFF set i2c1_clockspeed_khz = 800 set i2c2_pullup = OFF set i2c2_clockspeed_khz = 800 set i2c3_pullup = OFF set i2c3_clockspeed_khz = 800 set i2c4_pullup = OFF set i2c4_clockspeed_khz = 800 set mco2_on_pc9 = OFF set scheduler_relax_rx = 25 set scheduler_relax_osd = 25 set serialmsp_halfduplex = OFF set timezone_offset_minutes = 0 set rpm_filter_harmonics = 2 set rpm_filter_q = 500 set rpm_filter_min_hz = 100 set rpm_filter_fade_range_hz = 50 set rpm_filter_lpf_hz = 150 set stats_min_armed_time_s = -1 set stats_total_flights = 0 set stats_total_time_s = 0 set stats_total_dist_m = 0 set craft_name = Protek 35 set pilot_name = Ulysses set altitude_source = DEFAULT set altitude_prefer_baro = 100 set altitude_lpf = 300 set altitude_d_lpf = 100 set box_user_1_name = - set box_user_2_name = - set box_user_3_name = - set box_user_4_name = -
# profile 0 set profile_name = UAV Cine set dterm_lpf1_dyn_min_hz = 90 set dterm_lpf1_dyn_max_hz = 180 set dterm_lpf1_dyn_expo = 5 set dterm_lpf1_type = PT1 set dterm_lpf1_static_hz = 90 set dterm_lpf2_type = PT1 set dterm_lpf2_static_hz = 180 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_sag_compensation = 100 set pid_at_min_throttle = ON set anti_gravity_gain = 90 set anti_gravity_cutoff_hz = 5 set anti_gravity_p_gain = 100 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = OFF set iterm_relax = RP set iterm_relax_type = SETPOINT set iterm_relax_cutoff = 5 set iterm_windup = 85 set iterm_limit = 400 set pidsum_limit = 1000 set pidsum_limit_yaw = 1000 set yaw_lowpass_hz = 125 set throttle_boost = 5 set throttle_boost_cutoff = 15 set p_pitch = 75 set i_pitch = 134 set d_pitch = 76 set f_pitch = 199 set p_roll = 71 set i_roll = 127 set d_roll = 67 set f_roll = 191 set p_yaw = 71 set i_yaw = 127 set d_yaw = 0 set f_yaw = 191 set angle_level_strength = 50 set horizon_level_strength = 50 set horizon_transition = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set use_integrated_yaw = OFF set integrated_yaw_relax = 200 set d_min_roll = 67 set d_min_pitch = 76 set d_min_yaw = 0 set d_max_gain = 37 set d_max_advance = 20 set motor_output_limit = 100 set auto_profile_cell_count = 0 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 set thrust_linear = 20 set transient_throttle_limit = 0 set feedforward_transition = 0 set feedforward_averaging = OFF set feedforward_smooth_factor = 25 set feedforward_jitter_factor = 7 set feedforward_boost = 15 set feedforward_max_rate_limit = 90 set dyn_idle_min_rpm = 0 set dyn_idle_p_gain = 50 set dyn_idle_i_gain = 50 set dyn_idle_d_gain = 50 set dyn_idle_max_increase = 150 set level_race_mode = OFF set simplified_pids_mode = RPY set simplified_master_multiplier = 160 set simplified_i_gain = 100 set simplified_d_gain = 140 set simplified_pi_gain = 100 set simplified_dmax_gain = 0 set simplified_feedforward_gain = 100 set simplified_pitch_d_gain = 100 set simplified_pitch_pi_gain = 100 set simplified_dterm_filter = ON set simplified_dterm_filter_multiplier = 120 set tpa_mode = D set tpa_rate = 65 set tpa_breakpoint = 1350
# rateprofile 0 set rateprofile_name = UAV Cine set thr_mid = 50 set thr_expo = 0 set rates_type = ACTUAL set quickrates_rc_expo = OFF set roll_rc_rate = 1 set pitch_rc_rate = 1 set yaw_rc_rate = 1 set roll_expo = 70 set pitch_expo = 70 set yaw_expo = 70 set roll_srate = 100 set pitch_srate = 100 set yaw_srate = 70 set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 set roll_level_expo = 0 set pitch_level_expo = 0
DIFF ALL:
EnteringCLIMode,type'exit'toreturn,or'help'
# # Building AutoComplete Cache ... Done! # # diff all
# serial serial 0 131073 115200 57600 0 115200 serial 1 64 115200 57600 0 115200
# beacon beacon RX_LOST beacon RX_SET
# aux aux 0 0 3 1750 2100 0 0 aux 1 1 0 1750 2100 0 0 aux 2 13 1 1400 2100 0 0 aux 3 28 0 900 1725 0 0 aux 4 35 2 1300 1700 0 0
# master set gyro_lpf1_static_hz = 150 set gyro_lpf2_static_hz = 300 set dyn_notch_count = 2 set dyn_notch_max_hz = 550 set gyro_lpf1_dyn_min_hz = 150 set gyro_lpf1_dyn_max_hz = 300 set acc_lpf_hz = 10 set acc_calibration = 29,-29,-12,1 set rc_smoothing_auto_factor = 250 set rc_smoothing_auto_factor_throttle = 250 set rc_smoothing_setpoint_cutoff = 12 set rc_smoothing_feedforward_cutoff = 12 set rc_smoothing_throttle_cutoff = 20 set sbus_baud_fast = ON set align_board_yaw = 45 set yaw_motors_reversed = ON set small_angle = 180 set deadband = 5 set yaw_deadband = 5 set simplified_gyro_filter_multiplier = 60 set osd_cap_alarm = 1100 set osd_vbat_pos = 2304 set osd_rssi_pos = 162 set osd_link_quality_pos = 224 set osd_tim_2_pos = 2464 set osd_flymode_pos = 14560 set osd_vtx_channel_pos = 20 set osd_current_pos = 551 set osd_mah_drawn_pos = 583 set osd_craft_name_pos = 14656 set osd_pilot_name_pos = 14368 set osd_power_pos = 519 set osd_warnings_pos = 14392 set osd_avg_cell_voltage_pos = 2336 set osd_battery_usage_pos = 2072 set osd_disarmed_pos = 2251 set osd_esc_tmp_pos = 111 set osd_esc_rpm_pos = 11 set osd_displayport_device = MSP set vcd_video_system = HD set gyro_1_sensor_align = CW180 set gyro_1_align_yaw = 1800 set rpm_filter_harmonics = 2 set craft_name = Protek 35 set pilot_name = Ulysses
# profile 0 set profile_name = UAV Cine set dterm_lpf1_dyn_min_hz = 90 set dterm_lpf1_dyn_max_hz = 180 set dterm_lpf1_static_hz = 90 set dterm_lpf2_static_hz = 180 set vbat_sag_compensation = 100 set anti_gravity_gain = 90 set iterm_relax_cutoff = 5 set pidsum_limit = 1000 set pidsum_limit_yaw = 1000 set yaw_lowpass_hz = 125 set p_pitch = 75 set i_pitch = 134 set d_pitch = 76 set f_pitch = 199 set p_roll = 71 set i_roll = 127 set d_roll = 67 set f_roll = 191 set p_yaw = 71 set i_yaw = 127 set f_yaw = 191 set d_min_roll = 67 set d_min_pitch = 76 set thrust_linear = 20 set simplified_master_multiplier = 160 set simplified_d_gain = 140 set simplified_dmax_gain = 0 set simplified_dterm_filter_multiplier = 120
profile 1
profile 2
profile 3
# restore original profile selection profile 0
# rateprofile 0 set rateprofile_name = UAV Cine set roll_rc_rate = 1 set pitch_rc_rate = 1 set yaw_rc_rate = 1 set roll_expo = 70 set pitch_expo = 70 set yaw_expo = 70 set roll_srate = 100 set pitch_srate = 100 set yaw_srate = 70
rateprofile 1
rateprofile 2
rateprofile 3
# restore original rateprofile selection rateprofile 0
Based on the CLI dump you posted, your Serial Receiver Provider is currently set to SBUS. You need to set that to CRSF. Run the following commands in the CLI and then check for stick movements again in the Receiver tab...
feature TELEMETRY set serialrx_provider = CRSF save
If the Serial Receiver Provider isn't persisting as CRSF after you set it to that and then reboot the FC, make sure you have selected either the "CRSF,GHST,SBUS" or "CRSF" option as the Radio Protocol under the Build Configuration section when flashing firmware to the FC via the Betaflight Configurator Firmware Flasher tab.
(14-Jan-2024, 09:42 PM)SnowLeopardFPV Wrote: Com base no despejo CLI que você postou, seu provedor de receptor serial está atualmente definido como SBUS. Você precisa definir isso para CRSF. Execute os seguintes comandos na CLI e verifique os movimentos do stick novamente na guia Receptor... Se o Provedor do Receptor Serial não persistir como CRSF depois de configurá-lo para isso e reinicializar o FC, certifique-se de ter selecionado a opção "CRSF,GHST,SBUS" ou "CRSF" como o protocolo de rádio na seção Build Configuration ao atualizar o firmware para o FC por meio da guia Firmware Flasher do Betaflight Configurator.
Funcionou, meu amigo! Muito obrigado, fiz tudo que você explicou, atualizei o firmware do FC e selecionei a opção "CRSF,GHST,SBUS" como protocolo de rádio! Logo após a atualização, as stick bars apareceram e o RC funcionou!
(14-Jan-2024, 05:14 PM)SenaFPV Wrote: Hello my friends, good morning!
If the bars aren't showing up it means you don't have drivers for the selected protocol loaded. Reflash Betaflight making sure you have the correct protocol selected in the "Receiver protocols" section.
From the OP's last reply at the bottom of #post #9, having re-flashed the FC with the correct Radio Protocol selected it appears to have resolved the issue. A translated version of the OP's response is below...
SenaFPV Wrote:Funcionou, meu amigo! Muito obrigado, fiz tudo que você explicou, atualizei o firmware do FC e selecionei a opção "CRSF,GHST,SBUS" como protocolo de rádio! Logo após a atualização, as stick bars apareceram e o RC funcionou!
{Translated} SenaFPV Wrote:It worked, my friend! Thank you very much, I did everything you explained, updated the FC firmware and selected the "CRSF,GHST,SBUS" option as the radio protocol! Shortly after the update, the stick bars appeared and the RC worked!
