Flight controller not recognizing CRSF in betaflight
Hello my friends, good morning!
So, I have an F7 55A AIO Board Flight Controller and I installed crossfire, but when I go to Betaflight and change the receiver from SBUS to CRSF the stick bars disappear. Does anyone know what it could be?
Can you please run the "dump", "diff all", and "status" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
Please also post some good clear photos of the actual wiring and connections between your receiver and the flight controller.
(14-Jan-2024, 06:07 PM)SnowLeopardFPV Wrote: Can you please run the "dump", "diff all", and "status" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
ok i'll run these commands and post them here
DUMP:
board_name IFLIGHT_F745_AIO_V2
manufacturer_id IFRC
# name: Protek 35
# resources
resource BEEPER 1 D02
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 B04
resource MOTOR 4 B05
resource MOTOR 5 D12
resource MOTOR 6 D13
resource MOTOR 7 C08
resource MOTOR 8 C09
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 E08
resource SERIAL_TX 8 E01
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 E07
resource SERIAL_RX 8 E00
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 B08
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SCL 4 NONE
resource I2C_SDA 1 B09
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource I2C_SDA 4 NONE
resource LED 1 C13
resource LED 2 NONE
resource LED 3 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_SCK 4 E02
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MISO 4 E05
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource SPI_MOSI 4 E06
resource ADC_BATT 1 C03
resource ADC_RSSI 1 C05
resource ADC_CURR 1 C02
resource ADC_EXT 1 C01
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 A15
resource GYRO_EXTI 1 D00
resource GYRO_EXTI 2 D08
resource GYRO_CS 1 A04
resource GYRO_CS 2 B12
resource USB_DETECT 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer D12 AF2
# pin D12: TIM4 CH1 (AF2)
timer D13 AF2
# pin D13: TIM4 CH2 (AF2)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MOSI 4 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_MISO 4 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_TX 4 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma SPI_RX 4 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A08 0
dma pin B03 0
dma pin B00 0
dma pin B01 0
dma pin B04 0
dma pin B05 0
# pin B05: DMA1 Stream 5 Channel 5
dma pin D12 0
# pin D12: DMA1 Stream 0 Channel 2
dma pin D13 0
# pin D13: DMA1 Stream 3 Channel 2
dma pin C08 1
# pin C08: DMA2 Stream 4 Channel 7
dma pin C09 0
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature RX_SERIAL
feature OSD
feature ANTI_GRAVITY
serial 0 131073 115200 57600 0 115200
serial 6 0 115200 57600 0 115200
serial 7 0 115200 57600 0 115200
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 3 1750 2100 0 0
aux 1 1 0 1750 2100 0 0
aux 2 13 1 1400 2100 0 0
aux 3 28 0 900 1725 0 0
aux 4 35 2 1300 1700 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# rxfail
rxfail 3 a
rxfail 5 h
# master
set gyro_lpf1_type = PT1
set gyro_lpf1_static_hz = 150
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 300
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 2
set dyn_notch_q = 300
set dyn_notch_min_hz = 100
set dyn_notch_max_hz = 550
set gyro_lpf1_dyn_min_hz = 150
set gyro_lpf1_dyn_max_hz = 300
set gyro_lpf1_dyn_expo = 5
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set acc_calibration = 29,-29,-12,1
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 1
set baro_i2c_address = 0
set baro_hardware = AUTO
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rssi_smoothing = 125
set rc_smoothing = ON
set rc_smoothing_auto_factor = 250
set rc_smoothing_auto_factor_throttle = 250
set rc_smoothing_setpoint_cutoff = 12
set rc_smoothing_feedforward_cutoff = 12
set rc_smoothing_throttle_cutoff = 20
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = SBUS
set serialrx_inverted = OFF
set sbus_baud_fast = ON
set serialrx_halfduplex = OFF
set adc_device = 1
set blackbox_disable_rc = OFF
set blackbox_mode = NORMAL
set blackbox_high_resolution = OFF
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 550
set dshot_burst = OFF
set dshot_bidir = ON
set dshot_edt = OFF
set dshot_bitbang = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 15
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 45
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 100
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = ON
set mixer_type = LEGACY
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set small_angle = 180
set imu_process_denom = 2
set deadband = 5
set yaw_deadband = 5
set pid_process_denom = 1
set simplified_gyro_filter_multiplier = 60
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set ledstrip_brightness = 100
set osd_units = METRIC
set osd_warn_bitmask = 8191
set osd_rssi_alarm = 20
set osd_rsnr_alarm = 4
set osd_cap_alarm = 1100
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = 0
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 2304
set osd_rssi_pos = 162
set osd_link_quality_pos = 224
set osd_link_tx_power_pos = 341
set osd_rsnr_pos = 341
set osd_tim_1_pos = 341
set osd_tim_2_pos = 2464
set osd_remaining_time_estimate_pos = 341
set osd_flymode_pos = 14560
set osd_anti_gravity_pos = 341
set osd_g_force_pos = 341
set osd_throttle_pos = 341
set osd_vtx_channel_pos = 20
set osd_crosshairs_pos = 312
set osd_ah_sbar_pos = 313
set osd_ah_pos = 185
set osd_current_pos = 551
set osd_mah_drawn_pos = 583
set osd_wh_drawn_pos = 341
set osd_motor_diag_pos = 341
set osd_craft_name_pos = 14656
set osd_pilot_name_pos = 14368
set osd_gps_speed_pos = 341
set osd_gps_lon_pos = 341
set osd_gps_lat_pos = 341
set osd_gps_sats_pos = 341
set osd_home_dir_pos = 341
set osd_home_dist_pos = 341
set osd_flight_dist_pos = 341
set osd_compass_bar_pos = 341
set osd_altitude_pos = 341
set osd_pid_roll_pos = 341
set osd_pid_pitch_pos = 341
set osd_pid_yaw_pos = 341
set osd_debug_pos = 341
set osd_power_pos = 519
set osd_pidrate_profile_pos = 341
set osd_warnings_pos = 14392
set osd_avg_cell_voltage_pos = 2336
set osd_pit_ang_pos = 341
set osd_rol_ang_pos = 341
set osd_battery_usage_pos = 2072
set osd_disarmed_pos = 2251
set osd_nheading_pos = 341
set osd_up_down_reference_pos = 312
set osd_ready_mode_pos = 341
set osd_esc_tmp_pos = 111
set osd_esc_rpm_pos = 11
set osd_esc_rpm_freq_pos = 341
set osd_rtc_date_time_pos = 341
set osd_adjustment_range_pos = 341
set osd_flip_arrow_pos = 341
set osd_core_temp_pos = 341
set osd_log_status_pos = 341
set osd_stick_overlay_left_pos = 341
set osd_stick_overlay_right_pos = 341
set osd_rate_profile_name_pos = 341
set osd_pid_profile_name_pos = 341
set osd_profile_name_pos = 341
set osd_rcchannels_pos = 341
set osd_camera_frame_pos = 142
set osd_efficiency_pos = 341
set osd_total_flights_pos = 341
set osd_aux_pos = 341
set osd_sys_goggle_voltage_pos = 341
set osd_sys_vtx_voltage_pos = 341
set osd_sys_bitrate_pos = 341
set osd_sys_delay_pos = 341
set osd_sys_distance_pos = 341
set osd_sys_lq_pos = 341
set osd_sys_goggle_dvr_pos = 341
set osd_sys_vtx_dvr_pos = 341
set osd_sys_warnings_pos = 341
set osd_sys_vtx_temp_pos = 341
set osd_sys_fan_speed_pos = 341
set osd_stat_bitmask = 14124
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_displayport_device = MSP
set osd_framerate_hz = 12
set osd_aux_channel = 1
set osd_aux_scale = 200
set osd_aux_symbol = 65
set osd_canvas_width = 53
set osd_canvas_height = 20
set osd_craftname_msgs = OFF
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vcd_video_system = HD
set led_inversion = 0
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 1800
set gyro_2_bustype = SPI
set gyro_2_spibus = 2
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW180
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 1800
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set i2c4_pullup = OFF
set i2c4_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set scheduler_relax_rx = 25
set scheduler_relax_osd = 25
set serialmsp_halfduplex = OFF
set rpm_filter_harmonics = 2
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_lpf_hz = 150
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set craft_name = Protek 35
set pilot_name = Ulysses
set altitude_source = DEFAULT
set altitude_prefer_baro = 100
set altitude_lpf = 300
set altitude_d_lpf = 100
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
# profile 0
set profile_name = UAV Cine
set dterm_lpf1_dyn_min_hz = 90
set dterm_lpf1_dyn_max_hz = 180
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_type = PT1
set dterm_lpf1_static_hz = 90
set dterm_lpf2_type = PT1
set dterm_lpf2_static_hz = 180
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation = 100
set pid_at_min_throttle = ON
set anti_gravity_gain = 90
set anti_gravity_cutoff_hz = 5
set anti_gravity_p_gain = 100
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 5
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 1000
set pidsum_limit_yaw = 1000
set yaw_lowpass_hz = 125
set throttle_boost = 5
set p_pitch = 75
set i_pitch = 134
set d_pitch = 76
set f_pitch = 199
set p_roll = 71
set i_roll = 127
set d_roll = 67
set f_roll = 191
set p_yaw = 71
set i_yaw = 127
set d_yaw = 0
set f_yaw = 191
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 67
set d_min_pitch = 76
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 20
set feedforward_boost = 15
set dyn_idle_min_rpm = 0
set dyn_idle_p_gain = 50
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set level_race_mode = OFF
set simplified_master_multiplier = 160
set simplified_i_gain = 100
set simplified_d_gain = 140
set simplified_pi_gain = 100
set simplified_dmax_gain = 0
set simplified_dterm_filter_multiplier = 120
set tpa_mode = D
set tpa_rate = 65
set tpa_breakpoint = 1350
# rateprofile 0
set rateprofile_name = UAV Cine
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set roll_rc_rate = 1
set pitch_rc_rate = 1
set yaw_rc_rate = 1
set roll_expo = 70
set pitch_expo = 70
set yaw_expo = 70
set roll_srate = 100
set pitch_srate = 100
set yaw_srate = 70
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
# end the command batch
batch end
DIFF ALL:
# diff all
# Betaflight / STM32F745 (S745) 4.4.2 Jul  6 2023 / 20:27:59 (23d066d08) MSP API: 1.45
# config: YES
# start the command batch
batch start
defaults nosave
mcu_id 004b001d4d31501120363035
signature
# name: Protek 35
# resources
feature OSD
# beacon
beacon RX_LOST
beacon RX_SET
# master
set acc_lpf_hz = 10
set deadband = 5
# profile 0
set p_pitch = 75
set i_pitch = 134
set d_pitch = 76
set f_pitch = 199
set p_roll = 71
set i_roll = 127
set d_roll = 67
set f_roll = 191
set p_yaw = 71
set i_yaw = 127
set f_yaw = 191
set d_min_roll = 67
profile 1
profile 2
profile 3
# rateprofile 0
set yaw_rc_rate = 1
set roll_expo = 70
set pitch_expo = 70
set yaw_expo = 70
set yaw_srate = 70
rateprofile 1
rateprofile 2
rateprofile 3
# save configuration
save
STATUS:
# status
MCU F745 Clock=216MHz, Vref=3.29V, Core temp=49degC
Stack size: 2048, Stack address: 0x20010000
Configuration: CONFIGURED, size: 3166, max available: 32768
Devices detected: SPI:1, I2C:1
Gyros detected: gyro 1 locked dma
GYRO=BMI270, ACC=BMI270, BARO=DPS310
OSD: MSP (53 x 20)
BUILD KEY: f6a1b7d8cffa480b87581b1f1da5feb7 (4.4.2)
System Uptime: 10 seconds, Current Time: 2024-01-14T17:27:17.884+00:00
CPU:17%, cycle time: 309, GYRO rate: 3236, RX rate: 15, System rate: 10
Voltage: 44 * 0.01V (0S battery - NOT PRESENT)
I2C Errors: 0
FLASH: JEDEC ID=0x00ef4018 16M
Arming disable flags: RXLOSS CLI MSP RPMFILTER
The receiver is installed on UART 3
Based on the CLI dump you posted, your Serial Receiver Provider is currently set to SBUS. You need to set that to CRSF. Run the following commands in the CLI and then check for stick movements again in the Receiver tab...
feature TELEMETRY
set serialrx_provider = CRSF
save
If the Serial Receiver Provider isn't persisting as CRSF after you set it to that and then reboot the FC, make sure you have selected either the "CRSF,GHST,SBUS" or "CRSF" option as the Radio Protocol under the Build Configuration section when flashing firmware to the FC via the Betaflight Configurator Firmware Flasher tab.
  • SenaFPV, Coleon
(14-Jan-2024, 09:42 PM)SnowLeopardFPV Wrote: Com base no despejo CLI que você postou, seu provedor de receptor serial está atualmente definido como SBUS. Você precisa definir isso para CRSF. Execute os seguintes comandos na CLI e verifique os movimentos do stick novamente na guia Receptor... Se o Provedor do Receptor Serial não persistir como CRSF depois de configurá-lo para isso e reinicializar o FC, certifique-se de ter selecionado a opção "CRSF,GHST,SBUS" ou "CRSF" como o protocolo de rádio na seção Build Configuration ao atualizar o firmware para o FC por meio da guia Firmware Flasher do Betaflight Configurator.
feature TELEMETRY
save
Funcionou, meu amigo! Muito obrigado, fiz tudo que você explicou, atualizei o firmware do FC e selecionei a opção "CRSF,GHST,SBUS" como protocolo de rádio! Logo após a atualização, as stick bars apareceram e o RC funcionou!
(14-Jan-2024, 05:14 PM)SenaFPV Wrote: Hello my friends, good morning!
If the bars aren't showing up it means you don't have drivers for the selected protocol loaded. Reflash Betaflight making sure you have the correct protocol selected in the "Receiver protocols" section.
From the OP's last reply at the bottom of #post #9, having re-flashed the FC with the correct Radio Protocol selected it appears to have resolved the issue. A translated version of the OP's response is below...
SenaFPV Wrote:Funcionou, meu amigo! Muito obrigado, fiz tudo que você explicou, atualizei o firmware do FC e selecionei a opção "CRSF,GHST,SBUS" como protocolo de rádio! Logo após a atualização, as stick bars apareceram e o RC funcionou!
{Translated} SenaFPV Wrote:It worked, my friend! Thank you very much, I did everything you explained, updated the FC firmware and selected the "CRSF,GHST,SBUS" option as the radio protocol! Shortly after the update, the stick bars appeared and the RC worked!
  • V-22
  CrossFire Connection Issues-Radio Master Zorro- No Betaflight input Apex FPV 3 145 06-May-2024, 02:35 PM
  low flight times on 3.5 cinewoop technoflyer97 2 125 03-May-2024, 09:16 AM
Last Post: technoflyer97
  Flight time decreased Billybobthe3 8 213 01-May-2024, 10:57 PM
  problems connecting and writing code for the remote (esp32) and the flight controller YarikVor 2 144 23-Apr-2024, 03:58 PM
Last Post: YarikVor
  Can I connect my DJI fpv v2 goggles to and dji fpv remote controller 2 to other drons qt179 4 243 08-Apr-2024, 10:57 AM
Last Post: roleyrev
