esc firmware issue
As long as you put the right firmware it doesnt matter which tool will put it there, im currently using andreym chrome configurator and for me it is great. Good part after you have switched the cables on motors that all of your esc will be in full sync ( every parameter)
Next step try to hover your quad Smile
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
BLHeli Conf shows red asterisks on the settings that are not in sync. I don't really understand what you're guys talking about, if you've experienced some issue, why I didn't see any word nor report from you?
Yup i think the problem was with flashing the firmware to esc and now it has been resolved
All the best
#19
No issue with blheli configurator. My problem was flashing the right firmware but with blheli configurator it allowed me to do it. Grisha0 was making sure I check to make sure everything is in sync. And it is.
#20
Ok, I misunderstood then. Update to 0.1.6 and don't forget to use "Save Log" should you run into problems.
I'll add an automatic bug report feature a bit later.
#21
Sorry to bother again guys but maybe there is an issue after all or is this normal. So i was able to finaly double check today if everything was synced. I connected to bheli conifgorator and didnt see an issue. I connected to blheli suite and it read all escs and showed that they were out of sync with the maste but all firmware was correct. I also had a update for AH20 16.5 so i flashed it in blheli suite without an issue but it still showed they were of out sync with master. So i changed ppm in throtle match all ecs. Eveything matched. I went into betaflight and recalibrtated the escs. Just to check i went into blheli suite again and showed out of sync with master after the calibration. Here are some screen shots i took in order of the event. Is this normal or is ther something wrong?
#22
That's the very reason why there is throttle calibration in first place, PPM min/max values shouldn't necessarily be exactly the same. You can ask BLHeliSuite not to complain about PPM min/max.
BLHeli Conf also has 16.5, why you did not flash it there?
P.S. Update BLHeli Configurator to 0.1.6, do you see the "Save Log" button in the bottom left corner? 0.1.6 highly increases usefulness of "Save Log" for me as a developer if you run into problems. Don't forget to "Save Log" whenever you have issues.
#23
Ok thanks so i sounds like everything is ok then. i didnt realize that blehil configurator had the 16.5 update i just seen it when i went into blheli suite because it prompted me for it. Sorry about all the questions but i appreciate the answers. Im still new to the hobby and im trying to learn so i wasnt sure. I definitely be using the blheli configurator from now on. I like how it is setup and the menus. It is much more easier to use and ill save log any time I encounter an issue
[-] The following 2 users Like rcandvideogameguy's post:
  • Grisha0, AndreyM
  Should you update firmware? Rob Axel 15 279 11 hours ago
Question Is it possible to test if an ESC works without soldering? HypnoToad 2 140 23-Mar-2024, 07:22 PM
Last Post: HypnoToad
  VTX issue - ATOMRC hurricane 5 bar1 1 176 10-Mar-2024, 12:36 PM
Exclamation Noob Question..... "VTX/ESC" Boards.... Coleon 12 345 02-Mar-2024, 12:35 PM
Last Post: Luk5569
Video Troubleshooting motor issue - I'm stuck, help! doraymon 7 303 25-Feb-2024, 05:48 PM
