Threads: 30
Likes Received: 45 in 32 posts
Likes Given: 60
1 01-Jun-2022, 07:00 PM (This post was last modified: 01-Jun-2022, 07:03 PM by Pekka.) They do like to drift a bit when hovering. You could try calibrating your sticks if possible on your transmitter.
Threads: 75
Likes Given: 3,949
121 01-Jun-2022, 08:11 PM (This post was last modified: 01-Jun-2022, 08:11 PM by Lemonyleprosy.) Try giving it a bit more throttle and then repost a video if it’s still doing it a couple feet off the ground. You’re barely off the ground and sitting in all of the turbulent air from your props.
As Pekka said, they do drift a bit.
Dangerous operations.
Threads: 74
Likes Received: 1,341 in 999 posts
Likes Given: 781
41 I'm new as well to drones and I was surprised at how much mine drifted to the right. But getting it up a couple of metres did help and when it's moving at 20 mph, you don't really notice it anymore.
Saying that, if you are going forward at 20mph and its drifting massively to the left or right, then you might have a problem.
As Lemony suggested, post a video if you can.
Try Not, Do or Do Not
- Yoda
Threads: 75
Likes Given: 3,949
121 Assuming that that is you intentionally moving it away from the wall in the second half, I’m not seeing a significant amount of drift.
Threads: 38
Likes Given: 430
118 I think you are simply flying too close to the ground. Try and read up on ground effect.
Go outside, fly the quad at least 1.5 to 2 meters above the ground and keep moving away from your prop wash and then you should be able to guess if the quad is drifting.
FPV quads are not camera drones like the Mavic that have several sensors to stabilize the flight.
