Threads: 12
Likes Received: 1 in 1 posts
0 I am using a radiomaster boxer with a mobula7s. When I flip the Arm Switch and push the Left Throttle forward the Motors dont spin. However when I use the Right Throttle the motors do spin. (ARM is SA)
Can anyone please help me with this?
soky157
Threads: 12
0 Hello and thank you for helping me. My Boxer is SET to MODE 2.
Threads: 60
Likes Received: 1,015 in 734 posts
Likes Given: 96
52 Are you in turtle mode? If you are then moving the right stick (pitch/roll) will spin up the motors in the opposite direction. If you have OSD on your FPV feed, check there, it should tell you if you are in FLIP OVER AFTER CRASH mode.
Threads: 12
0 on the OSD is shows CRASH FLIP SWITCH. On my Boxer I do not have the Turtle Mode activated tho.
Threads: 60
Likes Given: 96
52 Check in the BF modes tab to see which switch/position is mapped, you may need to adjust it to match your radio/preference.
Threads: 12
0 Thank you very much for your help. I am now able to arm my Quad again!
