Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 06-May-2021, 04:59 AM Hey, I'm having trouble setting the SmartAudio up FC is a Succex E F4 v2.1 VTX is a AKK Infinite DVR I connected SmartAudio port labeled TBS in vtx to T1, configured uart1 at ports tab as TBS SmartAudio. Yes, I connected a lipo, imported vtx tables from akk (for some reason I can't set up the 1000mw, the max value seems to be 3 digits on the power field). I checked continuity between TBS pad on the vtx and another T1 pad on the FC, seems to be fine. dump: https://pastebin.com/eJZzty0H I'm out of ideas to try, anyone can help me? • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 Power level 3 is your max output. On your table, you have it labeled as 800 when it should be labeled 1000w. You can just run this in CLI. vtxtable powerlabels 25 200 600 1000 Save • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 06-May-2021, 05:26 AM (This post was last modified: 06-May-2021, 05:27 AM by rafareusch.) (06-May-2021, 05:22 AM)voodoo614 Wrote: Power level 3 is your max output. On your table, you have it labeled as 800 when it should be labeled 1000w. You can just run this in CLI. vtxtable powerlabels 25 200 600 1000 Save Setting the way you mentioned, the level 3 shows 100 at the UI, this is expected right? Still showing 100 even on CLI # vtxtable vtxtable bands 5 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 0 5885 5905 0 0 vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 4 vtxtable powervalues 0 1 2 3 vtxtable powerlabels 25 200 600 100 • Posts: 1,505 Threads: 49 Likes Received: 713 in 524 posts Likes Given: 477 Joined: Oct 2020 Reputation: 93 Power labels are limited to 3 characters. You can use 1W instead of 1000. • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 (06-May-2021, 07:03 AM)V-22 Wrote: Power labels are limited to 3 characters. You can use 1W instead of 1000. Still device ready no, even with 1W as the 3 level • Posts: 157 Threads: 7 Likes Received: 55 in 42 posts Likes Given: 33 Joined: Jan 2021 Reputation: 0 We may still have a miss communication, the vtx table power labels 25 200 600 1W ,, that's how it should read. Hope that helps. • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 Still, even doing the configuring the level 3 to 1W still not working, I still get device ready no. • Posts: 2,349 Threads: 118 Likes Received: 812 in 659 posts Likes Given: 126 Joined: Feb 2021 Reputation: 20 I recently replaced my AKK /dvr vtx... I continually “upped” the power and the signal never improved.. Dropped $14 on a PandaRC vtx and I was AMAZED how much better the signal was (and proper working order) with a proper working part.. • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 (06-May-2021, 02:54 PM)Rob Axel Wrote: I recently replaced my AKK /dvr vtx... I continually “upped” the power and the signal never improved.. Dropped $14 on a PandaRC vtx and I was AMAZED how much better the signal was (and proper working order) with a proper working part.. I can't complain, in testing my video feed seems to be crystal clear at 600mw, But I need more time to test to be sure. but thanks for the input. • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 Okay I can confirm that even using 1W as the level 3 still not solved the issue. I know it's not the VTX problem because I used SmartAudio before my older FC burnt. Could this be a problem at UART1? • Posts: 1,505 Threads: 49 Likes Received: 713 in 524 posts Likes Given: 477 Joined: Oct 2020 Reputation: 93 It certainly could be a problem with the UART. There are also a number of reports of people having issues with these boards due to poor QC. If another UART does not work I'd contact the vendor for an exchange. • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 06-May-2021, 09:54 PM (This post was last modified: 07-May-2021, 05:51 PM by rafareusch.) Okay guys, according to this thread: https://intofpv.com/t-f4-succex-e-f405-t...ing?page=3 Seems that Succex E F4 doesnt like SA in T1 pad (Theres a guy saying thats a Betaflight bug, he tested on emuflight and T1 works fine) . I'm not able to try it on mine atm but I believe this is the solution. Hope this helps someone that had this issue too. EDIT: Didn't solved my issue Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 Unfortunately I'm into another issue. I'm Trying to change channel via the push button, but the vtx doesnt seems to respond, the record button works fine. but the channel/band/power one does nothing. Am I missing something here? • Posts: 1,197 Threads: 59 Likes Received: 592 in 395 posts Likes Given: 210 Joined: Mar 2019 Reputation: 42 (07-May-2021, 01:38 AM)rafareusch Wrote: Unfortunately I'm into another issue. I'm Trying to change channel via the push button, but the vtx doesnt seems to respond, the record button works fine. but the channel/band/power one does nothing. Am I missing something here? Are you doing this with smartaudio connected? It varies on the VTX, but when connected smartaudio often takes control of the VTX, not allowing you to change channel or power with the button on the VTX. I have had problems at the field with smartaudio and had to cut the wire so I could change channels. • Posts: 37 Threads: 9 Likes Received: 1 in 1 posts Likes Given: 5 Joined: Mar 2021 Reputation: 0 (07-May-2021, 01:52 AM)bffigjam Wrote: Are you doing this with smartaudio connected? It varies on the VTX, but when connected smartaudio often takes control of the VTX, not allowing you to change channel or power with the button on the VTX. I have had problems at the field with smartaudio and had to cut the wire so I could change channels. Yes, smart audio is connected but it is not working in betaflight. • |
