Threads: 18
Likes Received: 3 in 3 posts
Likes Given: 3
0 • Posts: 4,550
Threads: 38
Likes Given: 430
118 20-May-2022, 07:53 AM (This post was last modified: 20-May-2022, 09:54 AM by kafie1980.) Try going into the Betaflight OSD in your goggles > VTX> VTX_SA> Op mode> Free and Save. Power cycle the quad.
If that doesn’t work then remove the SA wire and use the button to ensure the vtx can get into the correct band/channel/power setup as a test.
If that doesn't work then hold the button on the VTX for more than 12 seconds after powering up so it can exit pitmode.
Threads: 38
Likes Given: 430
118 STATX? The OSD will show this if SmartAudio fails to communicate with the VTX.
I am starting to think the SA pad or logic on the VTX is not working.
Not sure if this is also related to the Betaflight akk_vtx_fix issue that was around a few years ago where the AKK was using a non-standard SA protocol or something.
Threads: 38
Likes Given: 430
118 RDQ does rebrand stuff and they do not have any manufacturing facilities.
There is one example I can find where the AKK VTX patch was accidentally left out of the compiled Betaflight release but i am on my phone and can’t find it now. So its not uncommon.
Try asking RDQ for a replacement.
Threads: 38
Likes Given: 430
118 27-May-2022, 09:49 AM (This post was last modified: 27-May-2022, 09:49 AM by kafie1980.) I doubt its the plug since you mentioned that the Rush vtx works with the same plug in a previous post.
If the previous report is correct then its an issue with the SnartAudio implementation on the vtx or Betaflight firmware.
Threads: 18
Likes Given: 3
0 I can't be the only person with a IFLIGHT SUCCEX FC and RDQ Mach 3.1 VTX combination and having this problem then.... Doesn't seem like the AKK BF branch is a thing with the last few years.
Buy another VTX and see if have better luck?
Threads: 18
Likes Given: 3
0 Too late.
Already returned the RDQ and found another source for the Rush Tank. Just got it today and now smartaudio is working as expected.
Threads: 38
Likes Given: 430
118 The reason I circled that image was possible UARTS you can test the VTX for the Smart Audio issue you were facing.
